[其他器件] DATASHEET_BM010
查看512 | 回复0 | 2016-6-28 08:41:15 | 显示全部楼层 |阅读模式
USB to Serial Converter – BM010
OPEN SOURCE HARDWARE MODULE
Asynchonous serial data transmission from 300BPS to 115200BPS
3.3V or 5.0V operation
Serial communication pins can work down to 1.8V by supplying that voltage at the
VDDIO pin
TX(DOUT), RX(DIN), and power indicator LEDs
On-board USB mini type B connector
• TX(DOUT), RX(DIN), CTS, and DTR serial port pins
DATASHEET_BM010.pdf (299 KB, 下载次数: 0)
