重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | CA1 | C0805 | 22UF | C0805 | CON1 | DIP3P-2R54 | CN-3P | DIP3P-2R54 | CON2 | 3111-34SGOBK001A1 | 3111-34SGOBK00A1 | 3111-34SGOBK00A1_0 | CON11 | 3111-34SGOBK001A1 | 3111-34SGOBK00A1 | 3111-34SGOBK00A1_0 | CP1 | C0603 | 0.1UF | C0603 | D1 | 1N5819 | NC_1N5819 | 1N5819 | D4 | 1N5819 | NC_1N5819 | 1N5819 | D5 | LED0603 | LED | LED_0 | D6 | SMB | SK34 | SMB | D12 | SMD-220 | 6TQ045S | SMD-220 | D13 | SMD-220 | 6TQ045S | SMD-220 | D14 | SMC-6/8-MBRS340T3 | NC_1N5819 | SMC-6/8-MBRS340T3 | D18 | D1206 | 1N4148 | D1206 | D19 | D1206 | 1N4148 | D1206 | D21 | 35MILPAD12MILDRILL | TP03MM | 35MILPAD12MILDRILL | D22 | 35MILPAD12MILDRILL | TP03MM | 35MILPAD12MILDRILL | D23 | SMB | SK34 | SMB | E21 | 35MILPAD12MILDRILL | TP03MM | 35MILPAD12MILDRILL | E22 | 35MILPAD12MILDRILL | TP03MM | 35MILPAD12MILDRILL | F21 | 35MILPAD12MILDRILL | TP03MM | 35MILPAD12MILDRILL | F22 | 35MILPAD12MILDRILL | TP03MM | 35MILPAD12MILDRILL | FB1 | L0603 | 0R | L0603 | H1 | MTHOLE-3.5 | 3_5MM_8VIA | MTHOLE-3.5 | H2 | MTHOLE-3.5 | 3_5MM_8VIA | MTHOLE-3.5 | H3 | MTHOLE-3.5 | 3_5MM_8VIA | MTHOLE-3.5 | H4 | MTHOLE-3.5 | 3_5MM_8VIA | MTHOLE-3.5 | J1 | HEAD5_100MIL | 70247-1051 | HEAD5_100MIL | J2 | DVI-DA-24 | DVI-RECEPTACLE | DVI-DA-34 | J6 | SIP2.54-4P | 4PIN_2.54MM | SIP2.54-4P | J7 | SIP2.54-4P | 4PIN_2.54MM | SIP2.54-4P | J8 | FPC_50_TPC | TM070RBH10-20 | FPC_50_TPC | J9 | FPC_60_TPC | LSA40AT9001 | FPC_60_TPC | J10 | CONN_2P_PH3.5_SMD | SM02B-BHSS-1-TB/10INCH | CONN_2P_PH3.5_SMD | J11 | 1.0C-4PBX | 1.0MMX4/7INCH | 1.0C-4PBX | J12 | POWER_JACK_LUOWEI | PJ-002AH | POWER_JACK_LUOWEI | J13 | SIP2.54-4P | 2.54MMX4/10INCH | SIP2.54-4P | JTAG1 | HEAD5X2 | ARM_JTAG | HEAD5X2 | JTAG_TDO | MTHOLE-0.5 | 0_5MM_VIA | MTHOLE-0.5 | K1 | SW_4P_PUL02KA | NC_SW | SW_4P_PUL02KA | K2 | KEY_SMD | NC_SW_TACT-SPST | KEY_SMD | L1 | L-10X10 | 10UH_1A2 | L-10X10 | L4 | L-10X10 | 10UH_4A | L-10X10 | L5 | L0603 | BLM21B601S | L0603 | L6 | 805 | BLM21PG221SN1D | L0805 | L7 | 805 | BLM21PG221SN1D | L0805 | L8 | 805 | BLM21PG221SN1D | L0805 | L9 | 805 | BLM21PG221SN1D | L0805 | L19 | L0603 | ACDRH7D15-100NT | L0603 | L20 | ACDRH7D15 | ACDRH7D15-100NT | ACDRH7D15 | L21 | R0603 | M-300R-100MHZ | R0603 | L22 | R0603 | M-300R-100MHZ | R0603 | L23 | R0603 | M-300R-100MHZ | R0603 | L24 | R0603 | M-300R-100MHZ | R0603 | L27 | L-MS1305 | HC9-22R | L-MS1305 | L28 | L-MS1305 | HC9-22R | L-MS1305 | L29 | L-MS1305 | HC9-2.9R | L-MS1305 | LED1 | R0603 | LED | R0603 | LED_FB | MTHOLE-0.5 | 0_5MM_VIA | MTHOLE-0.5 | OE2 | MTHOLE-0.5 | 0_5MM_VIA | MTHOLE-0.5 | P1 | EP4CE40F484 | EP4CE40F484 | EP4CE40F484 | P3 | RCA-102 | RCA-102 | RCA-102 | Q1 | SOT-23 | 2N3904 | SOT-23 | Q2 | SOT_23 | AO3401 | SOT_23 | Q3 | 2N3904 | 2N3904 | 2N3904 | Q4 | UP04878 | UP04878 | UP04878 | U1 | SOP8-EP | FR9886D | RF9886D | U3 | SOT223 | AP1117E-25 | SOT223 | U6 | SOP8-EP | FR9886D | RF9886D | U7 | SOP8-255-50 | M25P32-VMW6TG-16M | SOP8-255-50 | U8 | TSSOP_54 | IS42S16800F/IS45S16800F | TSSOP_54 | U9 | TSSOP_54 | IS42S16800F/IS45S16800F | TSSOP_54 | U10 | TSSOP_54 | IS42S16800F/IS45S16800F | TSSOP_54 | U11 | TQFP144 | STM32F103ZT6 | TQFP144 | U12 | TSOP44_II | IS61LV25616-10T | TSOP44_II | U13 | SST25VF016-SOIC8 | SST25VF016B-50-4C-S2AF | AT45D011/SOIC_2 | U15 | FMQ | BUZZER_TMB12A05 | FMQ | U16 | W5100-80P | W5100 | W5100-80P | U17 | W5100-80P | W5100 | W5100-80P | U18 | SO16NB | MAX3232CSE | SO16NB | U20 | SO16NB | MAX3232CSE | SO16NB | U24 | ADV7180_40 | ADV7180BCPZ | ADV7180_40 | U25 | QFP144PIN-2 | SIL9135A_5 | SIL9135A | U27 | TQFN-24 | MAX17075/AAT1176 | TQFN-24 | U28 | SOT-23 | BAT54S | SOT-23 | U29 | SOT-23 | BAT54S | SOT-23 | U30 | SOT-23 | BAT54S/NC | SOT-23 | U31 | SOT23-6 | AAT1506-S3-T | SOT23-6 | U32 | SSOP-16 | ADS7846 | SSOP-16 | U48 | TO-263 | LM2679-ADJ | TO-263 | U49 | TO-263 | LM2679-ADJ | TO-263 | U50 | R-PDSO-G16 | TPS40055 | R-PDSO-G16 | U51 | SO-8 | SI4884DY | SO-8 | U52 | SO-8 | SI4884DY | SO-8 | U53 | STS12 | STS21 | STS21_0 | VCOM | MTHOLE-0.5 | 0_5MM_VIA | MTHOLE-0.5 | VCOM1 | MTHOLE-0.5 | 0_5MM_VIA | MTHOLE-0.5 | VGH | MTHOLE-0.5 | 0_5MM_VIA | MTHOLE-0.5 | VGL | MTHOLE-0.5 | 0_5MM_VIA | MTHOLE-0.5 | VR1 | TMC2K2J | TMC2K2J/NC | TMC2K2J | X1 | 3225 | 28.63636MHZ | 3225 | XON | MTHOLE-0.5 | 0_5MM_VIA | MTHOLE-0.5 | Y1 | X-7MMX5MM | 25MHZ/50PPM | X-7MMX5MM | Y2 | XTAL\HC49\F | 8M | XTAL\HC49\F | Y3 | XTAL\HC49\F | 25M | XTAL\HC49\F | Y4 | XTAL\HC49\F | 25M | XTAL\HC49\F | Y5 | X_SMD | 28.322M | X_SMD |
EP4CE40F484.7z
(811 KB, 下载次数: 33)
重要提示:PCB作品文件展下载说明
