[PADS9.5以下] IT9852智能人机一体板标准开发板PCB和原理图480x272(IT9852+ALC
查看11874 | 回复12 | 2017-11-26 12:45:46 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePart TypePCB DecalValue
CM1CHOKE_0CHOKE_0805Choke_0805
CM2CHOKE_0CHOKE_0805Choke_0805
CON1HEADER_4_5TU1252WNV-05TU1252WNV-05
CON2USB_PORTA_1CKS-001FA-A1NWUSB Port A
CON3USB_PORT_MINI_BCON_MINI-USB-0.8-1USB_Mini B
D1DIODE_2SOD323FRB751V
D2DIODE_ZENER_0DO-214ACSS24L
D6DZ_DUAL_CA_KKJ_3SOT-523NC/Rclamp0502B_SC-75_3L
D7DZ_DUAL_CA_KKJ_3SOT-523NC/Rclamp0502B_SC-75_3L
D8DIODE_2SOD323FRB751V
D9DIODE_2SOD323FRB751V
D10DZ_DUAL_CA_KKJ_3SOT-523Rclamp0502B_SC-75_3L
D11DZ_DUAL_CA_KKJ_3SOT-523Rclamp0502B_SC-75_3L
D12DIODE_ZENER_0DO-214ACSS24L
D13LED_0D0603LED_Red
F1THERMAL_FUSE_0F1206MF-NSMF150-2
H1TEST_POINT_0MTG3.0Hole
H2TEST_POINT_0MTG3.0Hole
H3TEST_POINT_0MTG3.0Hole
H4TEST_POINT_0MTG3.0Hole
J2HEADER_2_1FPHSI-102T1W000FPHSI-102T1W000
J3PHONEJACK_STEREO_SW_1TSH-369PHONEJACK STEREO SW
J4HEADER_8_3FPHSI-110T1W000HEADER 10/2.0
J5HEADER_5_2HEADER3X1/2.0HEADER3X1/2.0
J6HEADER_4_2FPHSI-104T1W000FPHSI-104T1W000
J7HEADER_5HEADER5X1/2.54HEADER 5X1/2.54
J8HEADER_5FPHSI-105T1W000HEADER 5
J9HEADER_3_3FPHSI-103T1W000FPHSI-103T1W000
J10HEADER_8_2FPHSI-105T1W000FPHSI-105T1W000
J11HEADER_8_2FPHSI-105T1W000FPHSI-105T1W000
J12HEADER_1X2_0HEADER2X1/2.0HD 1x2_2.0mm
J13HEADER_10_1TU1252WNV-06TU1252WNV-06
J14HEADER_2HEADER2X1/2.54HEADER 2
J155V_POWER_SOCKET_0SCD473DC_JACK-5V
L2INDUCTORZAD-4030LPC5015FT-2R2M-A
L3INDUCTORZAD-4030LPC5015FT-2R2M-A
L4INDUCTORZAD-4030LPC5015FT-2R2M-A
L6L_SMD_15UH_3.2AZAD-604510uH
Q1MOSFET_P_2SOT23-3P-1/GSDTSM2301
Q2NPN_3SOT23-3P-1/GSD-1MMBT3904
RN1RESARR_IS_4/SORP0402X433R
RN2RESARR_IS_4/SORP0402X433R
RN3RESARR_IS_4/SORP0402X433R
RN4RESARR_IS_4/SORP0402X433R
RN5RESARR_IS_4/SORP0402X433R
RN6RESARR_IS_4/SORP0402X433R
RST_KEY1SW_PUSHBUTTON_1PSW_STS-076System_RST
U1IT9852LQFP-128P-E/0.4/14X14IT9852
U2TS809CXC_1SOT23-3P-1/GSD-1TS3809CXF
U3EUP2584A_1TSOT25-5P/0.95/3X3VP3162
U7SP3232EU_4QFN-32P/0.4/4X4ALC5616
U8SP3232EU_0QFN-20P/0.4/3X3AW8733
U10NORFLAH_EN25B16SOP-8P/1.27/5X8MX25L12835FM2I-10G
U1103._SP458_SOICNSO-8P/1.27/5X6SP485_SOICN8
U12TO_TOUCH_0FPC-05-6PNC/To_Capacitor Touch
U1305._IT7831TS_TSOT25TSOT25-5P/0.95/3X3G5728T01
U1405._IT7831TS_TSOT25TSOT25-5P/0.95/3X3ETA3409/2A_out
U1505._IT7831TS_TSOT25TSOT25-5P/0.95/3X3G5728T01
U16MACRO_SD_CON_2C2002-C-00Macro SD Con
U18AT043TN25FPC-05-40P-RAT043TN25
Y1CRYSTAL_0_2XTAL-HC49USY212MHz
Y2CRYSTAL_2SF-321532.768k
重要提示:PCB作品文件展下载说明
老吴 | 2017-11-26 12:49:30 | 显示全部楼层
官方参考板。
IT9852_Control_Full_2L_RGB888_AT043TN25_GPIO_Table.zip (7 KB, 下载次数: 7)
ldj186 | 2017-11-27 08:29:23 | 显示全部楼层
o桃花岛主o | 2017-11-27 08:47:47 | 显示全部楼层
miaomiao | 2017-11-27 08:57:05 | 显示全部楼层
zhifang88 | 2017-11-27 08:57:08 | 显示全部楼层
yangtao0559 | 2017-11-28 20:40:48 | 显示全部楼层
feichi87 | 2017-12-1 08:56:46 | 显示全部楼层
mingli1998 | 2017-12-4 14:19:29 | 显示全部楼层
wxzl | 2018-11-29 15:33:45 | 显示全部楼层
这颗芯片的资料网上太少了,学习了也没地方买芯片啊
