[PADS9.5以下] SC7715A(SP7715A) +PN5441A2ET/C307XX+SR2351+SR3131 4层智能手机PCB和原
查看4182 | 回复9 | 2017-12-16 22:05:20 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePart TypePCB DecalValue
ANT0400CON-SPRING-PGC-1.5-2.8-3P-3.0PHCON-SPRING-PGC-1.5-2.8-3P-3.0PH
ANT7200CON-SPRING-PGC-1.5-3.5-2P-3.0PHCON-SPRING-PGC-1.5-3.5-2P-3.0PH
ANT7201CON-SPRING-PGC-1.5-3.5-2P-3.0PHCON-SPRING-PGC-1.5-3.5-2P-3.0PH
D0300DIODE-ZENER-PZ3D4V2HSOD-323-PRISEMI
D4100DIODE-SCHOTTKY-WSB5503W-2/TRSOD-323
D5100DIODE-LED-LTPL-C064WD-WADIODE-LED-LTPL-C064WD-WA
D6300DIODE-LED-WHITE-0603LED-0603
D6301DIODE-LED-WHITE-0603LED-0603
D6302DIODE-LED-WHITE-0603LED-0603
D7600TVS-PESD18VF1BLSOD-882NF
D7601TVS-PESD18VF1BLSOD-882NF
FB3101BEAD-1K-OHM-100MHZ-300MA-0402SL04021000ohm@100MHz
FB3106BEAD-1K-OHM-100MHZ-300MA-0402SL04021000ohm@100MHz
FB3107BEAD-1K-OHM-100MHZ-300MA-0402SL04021000ohm@100MHz
FB3108BEAD-1K-OHM-100MHZ-300MA-0402SL04021000ohm@100MHz
FB4100BEAD-470-OHM-100MHZ-0.5A-0603SL0603-S470ohm@100MHz 500mA
FB4102BEAD-1K-OHM-100MHZ-300MA-0402SL04021000ohm@100MHz
FB4103BEAD-1K-OHM-100MHZ-250MA-0402SL04021000ohm@100MHz(NF)
FB7201BEAD-1K-OHM-100MHZ-300MA-0402SL04021000ohm@100MHz
FD6201NC-FIDUCIALMARKPAD-FID
FD6202NC-FIDUCIALMARKPAD-FID
FD6203NC-FIDUCIALMARKPAD-FID
FD6204NC-FIDUCIALMARKPAD-FID
J0400CON-RF-SWITCH-MM8430-2610RA1CON-RF-SWITCH-MM8430-2610RA1
J3100CON-EAR-KJ367ANS-1BBJ03ACON-EAR-KJ367ANS-1BBJ03A
J4100CON-BTB-F-DF37NC-34DS-0.4VCON-BTB-F-DF37NC-34DS-0.4V
J4101CON-FPC-FH26-51S-0.3SHW(05)-REVCON-FPC-FH26-51S-0.3SHW(05)-REV
J4102CON-FPC-FH34SRJ-6S-0.5SHCON-FPC-FH34SRJ-6S-0.5SH(NF)
J5100CON-BTB-F-BBR43-30KB533_2CON-BTB-F-BBR43-30KB533_2
J5101CON-BTB-F-DF37NC-24DS-0.4VCON-BTB-F-DF37NC-24DS-0.4V
J6100CON-BAT-02-0321138-1CON-BAT-02-0321138-1
J6200CON-USB-MICRO-HY07-AB0700CON-USB-MICRO-HY07-AB0700
J6400SOCKET-SIM-CAF98-06206-SA00SOCKET-SIM-CAF98-06206-SA00
J6401SOCKET-SIM-WKSM018-3001SOCKET-SIM-WKSM018-3001
J6500SOCKET-CARD-TFLASH-TFRPN-S1015-TP00SOCKET-CARD-TFLASH-TFRPN-S1015-TP00
J7600CON-SPRING-PGC-1.5-6.0-2P-3.0PHCON-SPRING-PGC-1.5-6.0-2P-3.0PH(NF)
L0300IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-SPH25202.2uH
M6600MOTOR-F103030-146MOTOR-F103030-146(NF)
MIC3100AUDIO-MIC-ACMG4013-05S-443-006AUDIO-MIC-ACMG4013-05S-443-006
MIC3101AUDIO-MIC-ACMG4013-05S-443-006AUDIO-MIC-ACMG4013-05S-443-006
MLV6501MLV-AVLC5S02050SMLV0402(NF)
Q6101TRIODE-PNP-WPT2F30-6/TRSOT23-6
Q6102FET-N-LSK3019FP8TLSOT-416
Q7200FET-N-LSK3019FP8TLSOT-416
Q7600FET-N-WNM4002-3/TRSOT-523(NF)
REC3100AUDIO-RECEIVER-SDRP0612KJ02-F1-GAUDIO-RECEIVER-SDRP0612KJ02-F1-G
S6303SWITCH-PUSH-ST-1114RSWITCH-PUSH-ST-1114R
SPK3100AUDIO-SPK-DMSP1420KJ-10-GAUDIO-SPK-DMSP1420KJ-10-G
TL6203NC-PROBE-PAD-0.7X0.7-0.5MMNC-PROBE-PAD-0.7X0.7-0.5MM
TL6204NC-PROBE-PAD-0.7X0.7-0.5MMNC-PROBE-PAD-0.7X0.7-0.5MM
TL6205NC-PROBE-PAD-0.7X0.7-0.5MMNC-PROBE-PAD-0.7X0.7-0.5MM
TM4103NC-PROBE-PAD-D1.0-0.75MMNC-PROBE-PAD-D1.0-0.75MM
TM4104NC-PROBE-PAD-D1.0-0.75MMNC-PROBE-PAD-D1.0-0.75MM
TP0100NC-PADNC-PAD-0.5X0.5
TP6200NC-TP-JTAG-10PINNC-TP-JTAG-10PIN
TVS0300TVS-ESD5Z3.3T1G-3.3V-105PF-SOD-523SOD-523(NF)
TVS3125TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
TVS4102TVS-ESD5Z5.0T1GSOD-523NF
TVS6200TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
TVS6201TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
TVS6202TVS-ESD5Z7.0T1GSOD-523(NF)
U0100ASIC-SC7715A-570-0.4BGA13.3X12.1-570-0.4-SC7715A
U0201POWER-RTCBAT-XH311HG-IV07EPOWER-RTCBAT-XH311HG-IV07E3.3V(NF)
U0400RF-SW+PA-SKY77590-11RF-SW+PA-SKYWORKS-6X6-28PIN
U0401RF-TRANSCEIVER-SR3131RF-TRANSCEIVER-SR3131
U0402RF-SAW-DPX-B8558RF-SAW-2.0X1.6
U0403RF-SAW-DPX-B8078RF-SAW-2.0X1.6
U0404RF-SAW-B39881-B9400-K610RF-SAW-B39881-B9400-K610
U0405RF-SAW-SAWEN1G84CV0F00RF-SAW-SAWEN1G84CV0F00
U0406RF-PA-SKY77761RF-PA-SKYWORKS-3X3-10PIN
U0407RF-PA-SKY77762RF-PA-SKYWORKS-3X3-10PIN
U0409RF-PA-SKY77768RF-PA-SKYWORKS-3X3-10PIN
U0410RF-SAW-DPX-B8072RF-SAW-2.0X1.6
U0500MEM-NAND+LPDDR2-MT29RZ4C2DZZHGSK-18BGA11.5X13-162-0.5
U4100EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4101EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4102EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4103EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4104EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4105POWER-DC2DC-WD3119E-6/TRSOT23-6
U4106ASIC-SENSOR-TP-FT5306DE4QFN6X6-48
U4107EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U4108EMI-AVRC18S05Q015100REMI-AVRC18S05Q015100R
U5200SENSOR-MOTION-LIS3DHSENSOR-MOTION-LIS3DH
U5201SENSOR-MOTION-ST480MFSENSOR-MOTION-ST480MF
U5202SENSOR-LIGHT+PROX-LTR-553ALS-WASENSOR-LIGHT+PROX-LTR-553ALS-WA
U7200RF-SAW-LFB212G45CL1D172RF-SAW-LFB212G45CL1D172
U7201RF-SW+PA-2.4G-RFX8422RF-SW+PA-2.4G-RFX8422
U7202RF-SAW-SAFEA1G57KE0F00RF-SAW-1.35X1.05
U7203LOGIC-GATE-BUFFER-SN74AUC1G125DCKRSC70-5(NF)
U7204RF-LNA-GPS-BGU7005RF-LNA-GPS-BGU7005
U7205RF-SAW-SAFEA1G57KE0F00RF-SAW-1.35X1.05
U7206BT+WIFI+FM+GPS-SR2351BT+WIFI+FM+GPS-SR2351
U7207POWER-LDO-WL2801E33-5/TRSOT23-53.3V
U7600RF-NFC-PN5441A2ET/C307XXBGA4.5X4.5-64(NF)
X0200XTAL-CRYSTAL-32.768K-TFX-02-12.5-J01173XTAL-CRYSTAL-32.768K-TFX-02-12.5-J0117332.768K
X0401XTAL-CRYSTAL-E3SB26.0000F09G11CRYSTAL-26M26MHz
X7600XTAL-CRYSTAL-27M-E1AB27.1200F10E11XTAL-CRYSTAL-201627.12MHz(NF)
Y7200XTAL-TCXO-26MHZ-1XTW26000CCAXTAL-TCXO-26MHZ-1XTW26000CCA26MHz
重要提示:PCB作品文件展下载说明
老吴 | 2017-12-16 22:09:23 | 显示全部楼层
SP7715A_PCB.7z (2.39 MB, 下载次数: 15)
电子宅 | 2017-12-16 22:49:04 | 显示全部楼层
老吴又要大放资料了啊,到底有多少压箱底的
xnima_irumei | 2017-12-17 06:42:34 | 显示全部楼层
带刀的老鼠 | 2017-12-17 10:26:37 | 显示全部楼层
lovemeng252356 | 2017-12-17 10:53:57 | 显示全部楼层
miaomiao | 2017-12-17 11:26:05 | 显示全部楼层
zhonglan | 2017-12-17 13:11:54 | 显示全部楼层
ntpcbyanli4111 | 2017-12-18 14:42:37 | 显示全部楼层
苏北布衣 | 2020-9-12 14:06:48 | 显示全部楼层
