[Allegro16.6以下] PSoC® 6 BLE Pioneer Kit  CY8CKIT-062-BLE demo 板PCB和原理图
查看8160 | 回复53 | 2018-10-21 23:56:27 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
ANTWIGGLEANTENNA_7_ANT_MIFA_TAIL_Wiggle AntennaANT_MIFA_TAIL_3P69MM
CAP_SH1CAP_SHIELD_CAP_SH1_CAP_SHIELDCAP_SHIELDCAP_SH1
CSB1CAP_BUTTON_CIRCLE_MUTUAL_CSB_10Button 1CSB_10MM_3SEG
CSB2CAP_BUTTON_CIRCLE_MUTUAL_CSB__1Button 2CSB_10MM_3SEG
CSS1CAPSENSE SLIDER 5 SEGMUTUAL_2_SliderCSS_L5S_4X12_1P4_MUTUAL_CYPS
D1DIO STKYPMEG3020_DIO160X80X63-RB551SS-30T2RDIO160X80X63-2M
D2DIO STKYPMEG3020_DIO160X80X63-RB551SS-30T2RDIO160X80X63-2M
D3DIO STKYPMEG3020_SODFL4725X110PMEG3020BEPSODFL4725X110M
D9DIODEZENER_1_SOD3715X145M_BZT5BZT52C3V9-7-FSOD3715X145M
J1CON8_SULLINS_PPPC081LFBN-RC_CONCON8SULLINS_PPPC081LFBN-RC
J2CONN_8_SULLINS_PPPC102LFBN-R_FLCON 10x2SULLINS_PPPC102LFBN-R_FLIP
J3CON10_SULLINS_PPPC101LFBN-RC_COCON10SULLINS_PPPC101LFBN-RC
J4CON8_SULLINS_PPPC081LFBN-RC_CONCON8SULLINS_PPPC081LFBN-RC
J5RECPT 4X2100MIL_3_SULLINS_PPPCHDR 3x2SULLINS_PPPC032LFBN-RC_FLIP
J6CONN_7_SULLINS_PPPC082LFBN-R_FLCON 8x2SULLINS_PPPC082LFBN-R_FLIP
J7RECPT 4X2100MIL_5_SULLINS_PPPCCON 5x2SULLINS_PPPC052LFBN-RC_FLIP
J8103185_22-pin R/A HDRHARWIN_M20-9960245
J9TERMINAL_BLOCK_OST_OSTVN02A150_OSTVN02A150OST_OSTVN02A150
J10CONN_USB_TYPE_C_JAE_DX07S024XJ1USB TYPE-CJAE_DX07S024XJ1R1100
J11RECPT 4X2100MIL_2_CNC_3220-10-HDR_S 5x2CNC_3220-10-0100-00
J1220-PINCONNECTOR_CNCTECH_3220-2HDR_S 10x2CNCTECH_3220-20-0100-00
J13TESTPOINT_0_SAMTEC_BCS-101-L-SCON 2x1SAMTEC_BCS-101-L-S-HE
J14CON6_0_SULLINS_PPPC061LGBN-RC_FCON 6x1SULLINS_PPPC061LGBN-RC_FLIP
J15CONN FLEX2_JST_S2B-PH-K-S__HDRHDR_S 2x1_R/AJST_S2B-PH-K-S
J16TERMINAL_BLOCK_OST_OSTVN02A150_OSTVN02A150OST_OSTVN02A150
J17UFL_CONN_SMD_HIROSE_UFL-R-SMT-1U.FL-R-SMT-1(10)HIROSE_UFL-R-SMT-1
J18HEADER8_SULLINS_PBC08SAAN_HEADHEADER 8SULLINS_PBC08SAAN
J19HEADER10_SULLINS_PBC10SAAN_HEAHEADER 10SULLINS_PBC10SAAN
J20HEADER8_SULLINS_PBC08SAAN_HEADHEADER 8SULLINS_PBC08SAAN
L1INDUCTOR_INDC1005X60M_1NH1nHINDC1005X60M
L2INDUCTOR_INDC1005X60M_1NH1nHINDC1005X60M
L3INDUCTOR_INDC2016X100M_2.2UH2.2uHINDC2016X100M
L4INDUCTORFERRITE_INDC2012X105M_1K @ 100MHzINDC2012X105M
L5INDUCTOR_IND_ASPI-4020S-2R2N-T_2.2uHIND_ASPI-4020S-2R2N-T
L6INDUCTOR_INDM4242X200M__1.5UH1.5uHINDM4242X200M
L7INDUCTORFERRITE_INDC2012X105M_1K @ 100MHzINDC2012X105M
L8INDUCTORFERRITE_INDC2012X105M_1K @ 100MHzINDC2012X105M
L9INDUCTORFERRITE_INDC2012X105M_1K @ 100MHzINDC2012X105M
L10INDUCTOR_INDM4242X200M__1.5UH1.5uHINDM4242X200M
LED1LED_LEDC2012X120M_REDLEDRED LEDLEDC2012X120M
LED2LED_LEDC2012X120M_AMBERLEDAMBER LEDLEDC2012X120M
LED3LED_LEDC2012X120M_GREENLEDGREEN LEDLEDC2012X120M
LED4LED_LEDC2012X120M__AMBERLEDAMBER LEDLEDC2012X120M
LED5RGB_LED_LED_AAA3528LSEEZGKQBKS_RGB LEDLED_AAA3528LSEEZGKQBKS
LED6LED_LEDC2012X120M__REDLEDRED LEDLEDC2012X120M
LED7LED_LEDC2012X120M__GREENLEDGREEN LEDLEDC2012X120M
LED8LED_LEDC2012X120M_YELLOWLEDYELLOW LEDLEDC2012X120M
LED9LED_LEDC2012X120M_REDLEDRED LEDLEDC2012X120M
Q1MOSFET_N_GDS_10_SOIC127P600X175AO4838SOIC127P600X175-8M
Q2MOSFET_N_GDS_10_SOIC127P600X175AO4838SOIC127P600X175-8M
Q3PDGS_5_SOT95P237X111-3M_A_NTR4NTR4171PT1GSOT95P237X111-3M_A
Q4PDGS_4_SOT92P240X110-3M_DMP309DMP3098L-7SOT92P240X110-3M
Q5PDGS_5_SOT95P230X110-3M_PMV48XPMV48XP,215SOT95P230X110-3M
SH1SHORT_2_NET_TIE_COPPERTRACE_SHOShortNET_TIE_COPPERTRACE
SW1SWKEY-SPST_0_SW_EVQ-PE105K_EVQEVQ-PE105KSW_EVQ-PE105K
SW2SWKEY-SPST_0_SW_EVQ-PE105K_EVQEVQ-PE105KSW_EVQ-PE105K
SW3SW PUSH NO4-PIN_SW_SKRPACE010_SKRPACE010SW_SKRPACE010
SW4SW PUSH NO4-PIN_SW_SKRPACE010_SKRPACE010SW_SKRPACE010
SW5SW_SP3T_SW_CL-SB-13B-01T__CL-SBCL-SB-13B-01TSW_CL-SB-13B-01T
SW6SW_DPDT_JS202011CQN_1_SW_JS2020JS202011JCQNSW_JS202011JCQN
SW7SW_DPDT_JS202011CQN_1_SW_JS20_1JS202011JCQNSW_JS202011JCQN
TP1TP-43R_RREDKEYSTONE_5000
TP2TEST_POINT_KEYSTONE_5000_DISCREREDKEYSTONE_5000
TP3TEST_POINT_KEYSTONE_5000_IO_BLABLACKKEYSTONE_5000
TP5TEST_POINT_KEYSTONE_5000_DISCREREDKEYSTONE_5000
TP6TP-43R_RREDKEYSTONE_5000
TP7TEST_POINT_KEYSTONE_5000_DISC_1BLACKKEYSTONE_5000
TP8TEST_POINT_TP_17_DISCRETE_REDREDTP_17
TP9TEST_POINT_KEYSTONE_5000_DISCREREDKEYSTONE_5000
TP10TEST_POINT_KEYSTONE_5000_DISCREREDKEYSTONE_5000
TP11TEST_POINT_KEYSTONE_5000_DISCREREDKEYSTONE_5000
TP12TEST_POINT_KEYSTONE_5000_DISC_1BLACKKEYSTONE_5000
TP13TEST_POINT_KEYSTONE_5000_DISCREREDKEYSTONE_5000
TP14TEST_POINT_KEYSTONE_5000__REDREDKEYSTONE_5000
TP15TEST_POINT_KEYSTONE_5000_DISCREREDKEYSTONE_5000
TP16TEST_POINT_TP50_12D_24BOT_MIL__TP_SMDTP50_12D_24BOT_MIL
TP17TEST_POINT_TP50_12D_24BOT_MIL__TP_SMDTP50_12D_24BOT_MIL
TP18TEST_POINT_TP50_12D_24BOT_MIL__TP_SMDTP50_12D_24BOT_MIL
TP19TEST_POINT_TP50_12D_24BOT_MIL__TP_SMDTP50_12D_24BOT_MIL
TP20TEST_POINT_TP50_12D_24BOT_MIL__TP_SMDTP50_12D_24BOT_MIL
TVS1DT2636-04S-7_SOT65P210X110-6M__DT2636-04S-7SOT65P210X110-6M
TVS2DIODE BI-DIRTRIG_SOD2513X120M_SD12CT1GSOD2513X120M_DI
TVS3DIODE BI-DIRTRIG_SOD2513X120M_SD12CT1GSOD2513X120M_DI
TVS4TVS 5VSOD-323_0_SODFL1608X77M_ESD3V3D5-TPSODFL1608X77M
U1PSOC6_BLE_116_BGA_3_WFBGA116N50CY8C6347BZI-BLD43WFBGA116N50P10X12_520X640X70
U2CY8C38***-QFN68_1_QFN40P800X800CY8C5868LTI-LP039QFN40P800X800X100-69M
U3CYPD3125-40LQXIES_3_QFN50P600X6CYPD3125-40LQXIESQFN50P600X600X60-41M
U4S25FL512S_1_SOIC127P1030X265-16S25FL512SAGMFI011SOIC127P1030X265-16M
U5ULE_FRAM_SOIC127P800X203-8M_FM2FM25V10SOIC127P800X203-8M
U6MB39C022G_0_SON50P300X300X75-11MB39C022GPNSON50P300X300X75-11M
U7AP22802_0_SOT95P280X145-5M_74LV74LVCE1G126W5-7SOT95P280X145-5M
U8SIP32408_1_TDFN50P160X120X60-5MSiP32408TDFN50P160X120X60-5M
U9SIP32402ADNP_TDFN50P160X120X60-SIP32401ADNPTDFN50P160X120X60-5M
U10SIP32408_1_TDFN50P160X120X60-5MSiP32408TDFN50P160X120X60-5M
U11AP22802_0_SOT95P280X145-5M_74LV74LVCE1G126W5-7SOT95P280X145-5M
U12BTS4175SGA_SOIC127P600X175-8M__BTS4175SGASOIC127P600X175-8M
U13FXMA108_0_DQFN50P250X450X80-21MFXMA108BQXDQFN50P250X450X80-21M
U14BQ24266RGER_4_QFN50P400X400X100BQ24266RGERQFN50P400X400X100-25M
U15SIP32402ADNP_TDFN50P160X120X60-SIP32401ADNPTDFN50P160X120X60-5M
U16SIP32408_1_TDFN50P160X120X60-5MSiP32408TDFN50P160X120X60-5M
U17INA216A3RSW_2_QFN40P140X180X55-INA216A3RSWQFN40P140X180X55-10M
U18ISL95810UIU8Z-T_MSOP65P490X110-ISL95810UIU8Z-TMSOP65P490X110-8M
U19SIP32402ADNP_TDFN50P160X120X60-SIP32401ADNPTDFN50P160X120X60-5M
U20AP22802_3_SOT95P275X140-5M_TCR2TCR2EF18,LM(CTSOT95P275X140-5M
U21TPS63000_3_QFN50P250X300X100-15TPS63070QFN50P250X300X100-15M_NOFID
U22SIP32429_1_SON50P300X300X100-11SiP32429SON50P300X300X100-11M_VS
VCCDTEST_POINT_TP_17__TP_SMDTP_SMDTP_17
Y1ZTA_14_OSCCC200X250X65-4M_32MHZ32MHzOSCCC200X250X65-4M
Y2CRYSTAL_XTAL320X150X90N_ECS_32.32.768KHzXTAL320X150X90N_ECS
重要提示:PCB作品文件展下载说明
老吴 | 2018-10-21 23:59:23 | 显示全部楼层
CY8CKIT-062-BLE.7z (14.45 MB, 下载次数: 24)
ntpcbyanli4111 | 2018-10-22 07:13:05 | 显示全部楼层
ntpcbyanli4111 | 2018-10-22 07:14:57 | 显示全部楼层
lijun769954670 | 2018-10-22 08:11:40 | 显示全部楼层
ldj186 | 2018-10-22 08:16:13 | 显示全部楼层
lcfmax | 2018-10-22 08:27:58 | 显示全部楼层
zqshbs | 2018-10-22 08:38:49 | 显示全部楼层
williamtony | 2018-10-22 08:40:10 | 显示全部楼层
bofeng | 2018-10-22 08:43:32 | 显示全部楼层
