[eagle] MSP430I2040XPW+CC31XX_具有远程断开和 Wi-Fi 连接的智能插座
查看3120 | 回复4 | 2018-11-27 15:41:48 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
4层347PIN
游客,如果您要查看本帖隐藏内容请回复
Part       Value          Package      Library                 Position (mm)         Orientation
ANT1       AH316M         AH316M       Yuden_Ant               (0.75 8.8)            R270
C1         10u            C0603        resistor                (37 39.5)             R180
C2         0.1u           C0603        resistor                (37 35.5)             R0
C3         0.1u           C0603        resistor                (37 37.5)             R180
C4         0.47u          C0603        resistor                (33 40.5)             R0
C5         47pF           C0603        resistor                (47 31)               MR90
C6         150p           C0603        resistor                (45 33)               MR90
C7         47pF           C0603        resistor                (47 35)               MR90
C8         47pF           C0603        ElecMeter               (43.5 31)             R270
C9         150p           C0603        ElecMeter               (41 33)               R90
C10        47pF           C0603        ElecMeter               (43.5 35)             R270
C11        0.1u           C0402        rcl                     (18.5 27)             R0
C12        0.1u           C0201        rcl                     (16.55 21.5)          R90
C13        4.7u           C0402        rcl                     (20.15 8.5)           R0
C14        6p             C0402        rcl                     (7 14.5)              R180
C15        6p             C0402        rcl                     (5.2 18.4)            R90
C16        0.1u           C0201        rcl                     (9.95 15.45)          R180
C17        0.1u           C0201        rcl                     (21.5 10)             R0
C19        0.1u           C0201        rcl                     (23.5 15.5)           R0
C20        10u            C0402        rcl                     (23.2 14.8)           R0
C23        1u             C0201        rcl                     (10.5 9.9)            R180
C24        22u            C0603        rcl                     (19.6 5.8)            R270
C25        22u            C0603        rcl                     (18 3.5)              R180
C26        0.1u           C0201        rcl                     (9.5 14.5)            R180
C27        0.1u           C0402        rcl                     (10 6.5)              R90
C28        10u            C0402        rcl                     (11.1 6.5)            R90
C29        0.1u           C0201        rcl                     (15.5 21.5)           R90
C30        0.1u           C0201        rcl                     (22.5 13.5)           R0
C31        4.7u           C0402        rcl                     (14.375 6.95)         R270
C32        4.7u           C0402        rcl                     (15.35 6.95)          R270
C33        10p            C0201        rcl                     (10.5 11.5)           R0
C34        10u / 400V     E5-10,5      rcl                     (67 11)               R90
C35        6.2p           C0201        rcl                     (7.125 11.5)          R0
C36        0.1u           C0402        rcl                     (27 5)                R0
C37        10000p         C0201        rcl                     (10.5 10.4)           R180
C38        0.1u           C0603        rcl                     (56.5 8.5)            MR180
C39        18u            E5-5         rcl                     (54 14.5)             R270
C40        820u           E3,5-8       rcl                     (45 15.5)             R0
C41        10u            C1210        rcl                     (39 8.5)              R270
C42        0.1u           C0805        rcl                     (36.5 8.5)            R270
CC3101JTAG 5PinHeader     MA05-1       con-lstb                (9 30.5)              R0
CC3101UART 5PinHeader     MA05-1       con-lstb                (31.5 21.5)           R135
CC_RESET   DTSM-3         DTSM-3       switch-tact             (12 2.5)              R180
D3         SMAJ5.0CA      DO-214       CON1                    (52.5 35.5)           R270
D6         US1J-E3/5AT    DO-214AC     diode                   (67 2)                R0
D7         1SMB5954BT3G   DO-214AC     diode                   (62 4)                R270
D8         US1M-13-F      DO-214AC     diode                   (62 4)                MR270
D9         BAS20HT1G      SOD323-R     diode                   (54.5 6)              MR270
D10        B130LB-13-F    DO214AA      diode                   (39 5)                MR270
FLT1       1275A1         1275A1       TDK_RF_Filter           (8.25 11.5)           R180
GND_IN     GROUND_MALE    GROUND_MALE  Heyco_Connectors        (92 24)               R270
GROUNDOUT                 3,0-PAD      holes                   (67 24)               R270
K1         S212S01F       S212S01      Sharp_SSR               (94 5.5)              R0
L3         BLM21BD121SN1D L2012C       ElecMeter               (48.5 29.75)          R180
L4         BLM21BD121SN1D L2012C       ElecMeter               (48.5 36)             R180
L5         2.2u           2016         MurataInductors         (21.4 6.7)            R90
L7         1u             2520         MurataInductors         (17.25 5.4)           R0
L8         2.2u           2016         MurataInductors         (12.65 6.4)           R270
L9         5.6n           L0201        MurataInductors         (6.25 11.25)          R90
LED1                      CHIP-LED0603 led                     (22 20.5)             R90
LED2                      CHIP-LED0603 led                     (22 21.55)            R90
L_IN       MALE_BLADE     BLADE_MALE   Heyco_Connectors        (103.5 18)            R270
L_OUT      BLADE_FEMALE   BLADE_FEMALE Heyco_Connectors        (79.5 18)             R0
MSP430JTAG 14PinHeader    MA07-2       partsElecMeter_i4020Mod (10 35.5)             R0
N_IN       MALE_BLADE     BLADE_MALE   Heyco_Connectors        (103.5 30)            R270
N_OUT      BLADE_FEMALE   BLADE_FEMALE Heyco_Connectors        (79.5 30)             R180
OCS1       ECS-327SMO     ECS-327SMO   ECS_OSC                 (27.5 9.5)            R90
PWR                       MA03-1       con-lstb                (32.625 2.625)        R180
PWR_SEL                   MA03-1       ElecMeter               (4.875 40)            R0
Q1                        SOT23        semicon-smd-ipc         (40.5 24)             R270
R1         4.7k           R0603        ElecMeter               (27 41)               R180
R2         330k           R0603        ElecMeter               (53 31)               MR90
R3         330k           R0603        ElecMeter               (53 35)               MR90
R4         330k           R0603        ElecMeter               (51 35)               MR270
R5         100            R0603        ElecMeter               (49 31)               MR270
R6         S20K275        S20K275      varistor                (113 24)              R180
R7         3K             R0603        ElecMeter               (51 31)               MR90
R8         1K             R0603        ElecMeter               (49 35)               MR270
R9         1K             R0603        ElecMeter               (46.5 31.5)           R0
R10        1K             R0603        ElecMeter               (46.5 34.5)           R0
R11        10k            R0402        rcl                     (18.5 25.5)           R0
R12        10k            R0402        rcl                     (16 28.5)             R90
R13        39             R0603        rcl                     (43.5 23)             R90
R14        1k             R0603        rcl                     (37.5 26)             R90
R15        100k           R0201        rcl                     (10.5 10.95)          R180
R16        1k             R0402        rcl                     (24.5 20.5)           R0
R17        1k             R0402        rcl                     (24.5 21.55)          R0
R18        100k           R0201        rcl                     (7 21.75)             R180
R19        2.87k          R0603        rcl                     (60.5 9)              R90
R20        30.1k          R0603        rcl                     (56.5 10)             MR0
R21        76.8k          R0603        rcl                     (51.5 9.5)            MR270
R22        10             R0603        rcl                     (51.5 6)              MR90
R23        2.0k           R0603        rcl                     (34.5 8.5)            R90
R24        0              R0805        rcl                     (47.75 12.5)          MR0
R25        100k           R0201        rcl                     (11.75 8.25)          R90
R26        100k           R0201        rcl                     (10.75 9.2)           R270
R27        100k           R0201        rcl                     (7.75 19.975)         R180
R28        100k           R0201        rcl                     (21.875 12.5)         R0
R29        1k             R0201        rcl                     (14.5 5)              R180
R30        0              R0603        rcl                     (57 36)               MR0
R31        100k           R0201        rcl                     (21.8 13.75)          R270
R32        10k            R0201        rcl                     (18 24)               R180
R33        10k            R0201        rcl                     (12.25 28.05)         R0
R34        DNP            R0201        rcl                     (8.75 20.1)           R270
RSHUNT     4m             R4527        rcl                     (91 35)               R180
S1         DTSM-3         DTSM-3       switch-tact             (4.5 24)              R270
T1         CUSTOMTRANS    TRANS        RencoTransformer        (46 6)                R90
TP1        TPTP06R        TP06R        testpad                 (10.05 8.95)          R0
TP2        TPTP06R        TP06R        testpad                 (10 8)                R0
TP4        TPTP06R        TP06R        testpad                 (21.775 17.9)         R0
TP5        TPTP06R        TP06R        testpad                 (24.325 17.475)       R0
TP6        TPTP06R        TP06R        testpad                 (23.2 17.475)         R0
U1         MSP430I2040XPW TSSOP28      MSP430i204x             (32 31)               R90
U2         CC31XX         S-PVQFN-N64  CC31xx                  (21 19.5)             R180
U3         W25Q16V        8PINWSON     W25Q16V                 (10.5 27)             R270
U4         UCC28910D      SOIC(D)      UCC28910                (56.5 8)              R90
XT1        40MHz          FA-20H       Epson Crystals          (9 15)                R90
重要提示:PCB作品文件展下载说明
生活就是油盐酱醋再加一点糖,快活就是一天到晚乐呵呵的忙!
bidezhi7777 | 2018-11-27 22:56:26 | 显示全部楼层
shuszhao | 2018-11-28 06:48:01 | 显示全部楼层
mikewen | 2020-10-27 01:27:14 | 显示全部楼层
terren_lee | 2020-10-27 17:15:42 | 显示全部楼层
