重要提示:PCB作品文件展下载说明
Name | PCB Decal | Value | Part Type | ANT1 | ANT_3PIN | ANT-3PIN | ANT_3PIN | ANT10 | ANT_3PIN | ANT-3PIN | ANT_3PIN | CN1 | H6-PT2_0H3_2B | DIP6_2R0MM | H6-PT2_0H3_2B | CON10 | TFCARD | NC/TFCARD | TFCARD | D2 | ESD0402 | NC/ESD5451X | ESD0402 | D3 | ESD0402 | NC/ESD5451X | ESD0402 | D4 | ESD0402 | NC/ESD5451X | ESD0402 | D5 | ESD0402 | NC/ESD5451X | ESD0402 | D6 | ESD0402 | NC/ESD5451X | ESD0402 | D7 | ESD0402 | NC/ESD5451X | ESD0402 | D8 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D12 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D13 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D14 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D15 | ESD0402 | NC/ESD5451X | ESD0402 | D16 | ESD0402 | NC/ESD5451X | ESD0402 | D17 | ESD0402 | NC/ESD5451X | ESD0402 | D18 | SOD123 | XBS104S14 | SOD123 | D20 | LED-DIP1 | RED_BLUE_LED | LED-DIP1 | D23 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D24 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D25 | ESD0402 | NC/ESD9B5VL-2/TR | ESD0402 | D26 | ESD0402 | ESD9B5V-2/TR | ESD0402 | D27 | ESD0402 | ESD9B5V-2/TR | ESD0402 | D34 | SOD123 | NC/XBS104S14 | SOD123 | D35 | SOD123 | XBS104S14 | SOD123 | D48 | ESD0402 | NC/ESD5451X | ESD0402 | D60 | ESD0402 | NC/ESD5451X | ESD0402 | D62 | ESD0402 | NC/ESD5451X | ESD0402 | D63 | ESD0402 | NC/ESD5451X | ESD0402 | D64 | ESD0402 | NC/ESD5451X | ESD0402 | DU1 | FBGA96C80P9X13 | DDR3-FBGA96 | FBGA96C80P9X13 | DU2 | FBGA96C80P9X13 | DDR3-FBGA96 | FBGA96C80P9X13 | DU3 | FBGA96C80P9X13 | DDR3-FBGA96 | FBGA96C80P9X13 | DU4 | FBGA96C80P9X13 | DDR3-FBGA96 | FBGA96C80P9X13 | ESD2 | ESD0402 | NC/ESD5451X | ESD0402 | HCON1 | HDMI\YKF45-7012-1 | HDMI-001-05 | HDMI\YKF45-7012-1 | J3 | AV3-8.4-5 | AV3-8.4-5 | AV3-8.4-5 | J5 | SIP5-2.54MM | PH-2.54X5 | SIP5-2.54MM | J6 | PH-2.54X5A | PH-2.54X5 | PH-2.54X5A | J8 | RJ-45B | RJ45A | RJ-45B | J12 | DC-JACKA | DC-208 | DC-JACK | J21 | CON4_2.54 | PH-4A | CON4_2.54 | J22 | CON5/2.00MM/DIP_AL_A | PH-2.0-5 | CON5/2.00MM/DIP_AL_A | J25 | XH-2-2_54 | XH-2-2_54 | XH-2-2_54 | K1 | TS-026-3 | TS-026-3 | TS-026-3 | L6 | CD35 | 2.2UH | CD35 | L7 | CD35 | NC/2.2UH | CD35 | L8 | CD54 | 2.2UH-3A | CD54 | L9 | CD54 | 2.2UH-3A | CD54 | L10 | CD35 | 2.2UH | CD35 | L15 | PL_3X3_0.015 | 3.3UH | PL_3X3_0.015 | MASK1 | SMD | SMD | SMD | MASK2 | SMD | SMD | SMD | MASK3 | SMD | SMD | SMD | MASK4 | SMD | SMD | SMD | P2 | USB-AF-04-004C | USB-AF-04-004C | USB-AF-04-004C | P4 | USB-AF-04-004C | USB-AF-04-004C | USB-AF-04-004C | Q1 | SOT-23 | NC/2N3906 | SOT-23 | Q2 | SOT-23 | NC/2N3904 | SOT-23 | Q3 | SOT-23 | MMBT3904 | SOT-23 | Q4 | SOT-23 | MMBT3904 | SOT-23 | Q6 | SOT-23 | AO3423-PMOS | SOT-23 | Q9 | SOT-23 | MMBT3904 | SOT-23 | TVS1 | SMB | DO214 | SMB | U1 | BGA347P0_65B14X14 | H3-BGA3XX_11 | BGA347P0_65B14X14 | U10 | EMMC | EMMC5_0_BGA169 | EMMC | U11 | TSOP48 | NAND | TSOP48 | U22 | SMDTR16P | PM44-11BP | SMDTR16P | U24 | IIR | IR_MODULE | IIR | U27 | RCLAMP0524P | RRCLAMP0524P | RCLAMP0524P | U28 | RCLAMP0524P | RRCLAMP0524P | RCLAMP0524P | U39 | 8189ETV | 8189ETV | 8189ETV | U49 | SOT23-5 | LP3987H-33B5F | SOT23-5 | U50 | SOT23-5 | LP3987H-33B5F | SOT23-5 | U56 | SO8-OPT | RC4558 | SO8-OPT | U57 | AXP8036 | AXP8036 | AXP8036 | X1 | XTAL_3225 | 24MHZ_20PF | XTAL_3225 | X2 | MC-146 | 32K768_20PF | MC-146 | X7 | XTAL_3225 | 26MHZ_20PF | XTAL_3225 | XC31 | C0402 | 22PF | C0402 | XC41 | C0402 | 9PF | C0402 | XC121 | C0402 | 22PF | C0402 | XC130 | C0402 | 22PF | C0402 |
重要提示:PCB作品文件展下载说明
