[Pads_VX.2x] PET-A33 开发板 底板PCB和原理图共享
查看5420 | 回复17 | 2019-5-26 15:30:54 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalValuePart Type
A1SMA-KWESMA-KWE/NCSMA-KWE
A3SMA-KWESMA-KWESMA-KWE
BAT1BAT_CR12203VBAT_CR1220
CN1MIC_CZ034AP462CZ034AP462MIC_CZ034AP462
CN2HEADER_PIN_DIP2X25_2MMHEADER_2.0-2*25HEADER_PIN_DIP2X25_2MM
CN3HEADER_PIN_DIP2X10_2MMHEADER_2.0-2*10HEADER_PIN_DIP2X10_2MM
CON1FPC-50P-0M5FPC-50PIN-0.5-UPFPC-50P-0M5
CON2XH-5AWXH-5AWXH-5AW
D1DIO_SOD1231N5819WDIO_SOD123
D2DIO_SOD1231N5819WDIO_SOD123
D3SOT23BAT54SSOT23
D4DIO_SOD12318VDIO_SOD123
D5SOT23BAT54SSOT23
D6DIO_SOD1236VDIO_SOD123
D7DIO_SOD1231N5819WDIO_SOD123
D8DIO_SOD1231N5819WDIO_SOD123
D9R0603ULCE1005A015FR/NCR0603
D10R0603ULCE1005A015FR/NCR0603
D11SMASS34/NCSMA
D12DIO_SOD1231N5819WDIO_SOD123
D14LED0603REDLED0603
D15LED0603GREEN/NCLED0603
D17SKD_DIODE_SMD_SMASMBJ15CASKD_DIODE_SMD_SMA
D18R0603ULCE1005A015FR/NCR0603
D30SMASS34SMA
ESD1R0603ULCE1005A015FRR0603
ESD2R0603ULCE1005A015FRR0603
ESD3R0603ULCE1005A015FRR0603
ESD4SOD-323ESD03V32D-LC/NCSOD-323
ESD5SOD-323ESD03V32D-LC/NCSOD-323
ESD6SOD-323ESD03V32D-LC/NCSOD-323
ESD7SOD-323ESD03V32D-LC/NCSOD-323
F1F1206SMD1206P050TFF1206
F2F1206SMD1206P050TFF1206
F3F1206SMD1206P050TFF1206
F4F1206SMD1206P050TFF1206
F5FUSE1812SMD1812P200TSFUSE1812
ID4MARKID-BOARDFM4P
J1PJK647PJK-647PJK647
J2DB9RA/MDB-9P-04DB9-MALE
J3PH-4APH-4APH-4A
J4KF128-4PKF128-4P-5.08KF128-4P
J5KF128-4PKF128-4P-5.08KF128-4P
J6HEADER_PIN_DIP2X4_2MMHEADER_2.0-2*4HEADER_PIN_DIP2X4_2MM
J7XH-4AWXH-4AWXH-4AW
J8XH-4AWXH-4AWXH-4AW
J9USB8USB-2A-02USB8
J10USB8USB-2A-02USB8
J11HEADER_PIN_DIP2X5_2MMHEADER_2.0-2*5HEADER_PIN_DIP2X5_2MM
J12RJ45-LUIS041XHR911105AHR911105A
J13HEADER_PIN_DIP2X4_2MMHEADER_2.0-2*4HEADER_PIN_DIP2X4_2MM
J14FPC-FH26-21SFH26-21S-0.3SHWFPC-FH26-21S
J15HEADER_PIN_DIP2X11_2MMHEADER_2.0-2*11HEADER_PIN_DIP2X11_2MM
J16HEADER_PIN_DIP2X2_2MMHEADER_2.0-2*2HEADER_PIN_DIP2X2_2MM
J17HEADER_PIN_DIP2X10_2MMHEADER_2.0-2*10HEADER_PIN_DIP2X10_2MM
J18PH-6APH-6APH-6A
J19FPC-8P-0M5FPC-8PIN-0.5-DOWNFPC-8P-0M5
J20FPC_FH26_35SFH26-35S-0.3SHWFPC-FH26-35S
J21HEADER_PIN_DIP2X4_2MMHEADER_2.0-2*4HEADER_PIN_DIP2X4_2MM
J22XH-4AWXH-4AWXH-4AW
J23MICRO-USB-5S-BMICRO-USB-5S-BMICRO-USB-5S-B
J24TF_C-PTFBT1TF_CARDTF_C-PTFBT1
J25HEADER_PIN_DIP2X4_2MMHEADER_2.0-2*4HEADER_PIN_DIP2X4_2MM
J26DC-JACKDC-005-2.0DC-JACK
J52HXBSRQCON4APSKD_SZP-2
J53PH-2AWPH-2AWPH-2AW
J54PH-2AWPH-2AWPH-2AW
J55PH-4APH-4APH-4A
J56PH-4APH-4APH-4A
L1FB06032.7NHL0603
L2IND_4M4LVS404018-100M-N/NCIND_4M4
L3IND_4M4LVS404018-100M-NIND_4M4
L4IND_4M4LVS404018-4R7M-NIND_4M4
L5CD105PIO105-100MTCD105
L14IND_PIO75PIO75-100MTSKD_IND_PIO75
P1TP1MMTESTTP1MM
P2TP1MMTESTTP1MM
PWR1PAD_2M5_D1MMBAT+PAD_2M5_D1MM
PWR2PAD_2M5_D1MMNTCPAD_2M5_D1MM
PWR3PAD_2M5_D1MMBAT-PAD_2M5_D1MM
Q1SOT23AO3415ASOT23
Q2SOT23MMBT3904SOT23
Q3SOT232N7002SOT23
Q4SOT232N7002SOT23
Q5SOT23AO3415ASOT23
Q6SOT23MMBT3904SOT23
Q7SOT23MMBT3904/NCSOT23
SW73X6X3-53X6X3.53X6X3-5
SW8SW_SPDT_POWER-SWSMTS-102-2C3SW_SPDT_POWER-SW
U1A33_C_STEMA33STEMA33_C_STEM
U2A33_C_STEM2A33STEM2/NCA33_C_STEM2
U3MSOP8LY8006ULMSOP8
U4MSOP8LY8006ULMSOP8
U5SOP16MAX3232ESESOP16
U6LQFP-64FT4232HLLQFP-64
U7SO8N93C46/NCSOP8
U8SO8NMAX13487EESASOP8
U9SO8NPCA82C250SOP8
U10LQFP48FE2.1LQFP48
U11ACM2012-2PSMCF2012GH900AEACM2012-2P
U12ACM2012-2PSMCF2012GH900AEACM2012-2P
U13ACM2012-2PSMCF2012GH900AEACM2012-2P
U14ACM2012-2PSMCF2012GH900AEACM2012-2P
U15SOT23-5ME6211C33MSOT23-5
U16WIFI11N_28188ETV/NCWIFI11N_2
U17AP6210_SOP44_AP6S218723BSAP6210_SOP44_AP6S21
U18SOT23-6NL27WZU04DTT1G/NCSOT23-6
U19SOT23-6AP3032SOT23-6
U20SOT23-5ME6211C33MSOT23-5
U21SOT223AMS1117-3.3SOT223
U22SOT23-6AP3032SOT23-6
U23SO8NPCF8563TSOP8
U24SKD_SOT23-8MAX6369KASOT23-8
U25SKD_ACM2012-2PSMCF2012GH900AESMCF2012GH900AE
U26QFN12P0_5L1_9X1_9BMA250QFN12P0_5L1_9X1_9
U27SOP8_DDAMP1484ENSOP8_DDA
U28SOT23-6SY7152SOT23-6
X1SMT322512MHZSMT3225
X2SMT322512MHZSMT3225
X3SMT322526MHZSMT3225
X4SKD_OSCFC-13532.768KHZOSCFC-135
重要提示:PCB作品文件展下载说明
暑假期间,免费代管18-28岁小孩,限女性。
sii9000 | 2019-5-26 15:31:43 | 显示全部楼层
PCB 和原理图共享。
PET-A33.7z (662 KB, 下载次数: 22)
带刀的老鼠 | 2019-5-26 23:05:07 | 显示全部楼层
907321 | 2019-5-27 07:43:13 | 显示全部楼层
xia20802 | 2019-5-27 08:39:08 | 显示全部楼层
lcfmax | 2019-5-27 08:40:30 | 显示全部楼层
ltm99086 | 2019-5-27 08:53:41 | 显示全部楼层
yeyongjicn | 2019-5-27 08:54:21 | 显示全部楼层
gyj82117 | 2019-5-27 08:56:50 | 显示全部楼层
零依旧很灵 | 2019-5-28 08:33:31 | 显示全部楼层
长期免费代管18-28岁小
