[Pads_VX.2x] 门禁开关系统控制板PCB文件共享
查看7106 | 回复47 | 2019-5-28 18:48:58 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
序号物料名称规格型号单位用量位置号
1批头线5芯线,22#,150mm,2.54端子单头线,开尾剥皮15mm,线序(黄白黑棕红)pcs1接系统线
2PE袋180*120mm,自封PE袋pcs1
4螺丝PA3*10mm,镀锌pcs4固定外壳
5螺丝PA3*6mm,镀锌pcs4固定PCB
6易碎贴纸易碎贴pcs1
7型号标贴50*30mm,自行打印pcs1
8警告标45*30mmpcs1
9合格证33*30mm,三角标pcs1
10气泡袋250*220mmpcs1
11包装外盒220*110*50mm,白盒pcs1
12说明书pcs1
13中间设备套壳外壳1
15贴片ICSTC89C52RC,QFP-44pcs1U27
16贴片ICMAX485,SOP-8pcs9U2,U3,U5,U7,U8,U9,U11,U12,U13
17贴片ICLM324,SOP-14pcs2U25,U26
18贴片ICCD4053,SOP-16pcs3U1,U6,U10
19插件ICLM7805CV,TO-220pcs1U24
20插件ICLM7812CV,TO-220pcs1U23
21贴片电阻200Ω,±5%,0603pcs27R6,R7,R12,R16,R18,R23,R27,R29,R34,R39,R41,R46,R50,R52,R57,R61,R63,R68,R75,R78,R83,R88,R90,R95,R99,R104,R106
22贴片电阻1KΩ,±5%,0603pcs29R69,R71,R73,R77,R84,R116,R118,R120,R122-R124,R127,R128,R131-R134,R136,R138,R140,R142,-R144,R146,R147,R151-R154
23贴片电阻2KΩ,±5%,0603pcs8R107,R108,R109,R110,R111,R112,R113,R114
24贴片电阻4.7KΩ,±5%,0603pcs18R2,R5,R14,R15,R25,R26,R37,R38,R48,R49,R59,R60,R72,R74,R86,R87,R97,R98
25贴片电阻5.1KΩ,±5%,0603pcs10R1,R4,R13,R24,R36,R47,R58,R70,R85,R96
26贴片电阻10KΩ,±5%,0603pcs10R3,R17,R28,R35,R40,R51,R62,R76,R89,R100
27贴片电阻20KΩ,±5%,0603pcs18R155-R172
28贴片电阻47KΩ,±5%,0603pcs9R9,R20,R31,R43,R54,R65,R80,R92,R101
29贴片电阻100KΩ,±5%,0603pcs8R115,R117,R119,R121,R135,R137,R139,R141
30贴片电阻200KΩ,±5%,0603pcs9R10,R21,R32,R44,R55,R66,R81,R93,R102
31贴片电阻750KΩ,±5%,0603pcs8R125,R126,R129,R130,R145,R148,R149,R150
32贴片电容104,±10%,50V,0603pcs21C1,C2,C3,C5,C6,C9,C10-C21,C23,C25,C27
33贴片电容1uF,±10%,25V,0603pcs9C28,C29,C30,C31,C32,C33,C34,C35,C36
34贴片电容20pF,±5%,50V,0603,NPOpcs2C7,C8
35插件电解电容220uF,±20%,25V,Φ8*12mm,铝pcs2C24,C26
36插件电解电容220uF,±20%,35V,Φ8*12mm,铝pcs1C22
37插件电解电容10uF,±20%,16V,Φ4*8mm,铝pcs1C4
38插件晶振20MHZ,20pF,30PPM,HC-49/Spcs1Y1
39贴片三极管SS8050,SOT-23,Y1pcs17Q2,Q4,Q6,Q8,Q10,Q12,Q14,Q16,Q18-Q26
40贴片三极管SS8550,SOT-23,Y2pcs9Q27,Q28,Q29,Q30,Q31,Q32,Q33,Q34,Q35
41贴片二极管1N4148,LL-34pcs8D11-D14,D19-D22
42插件二极管1N5404,DO-27pcs1D10
43贴片发光二极管白发红,0805,普亮pcs13D23-D35
44贴片气体放电管BA401N,1812pcs10F4,F7,F9,F16,F20,F24,F28,F32,F36,F37
45插件气体放电管LT-B3R090L,陶瓷三脚封装pcs9U14,U15,U16,U17,U18,U19,U20,U21,U22
46贴片TVS管SMBJ6.5CA,SMBpcs27F1-F3,F5,F6,F8,F10-F15,F17-F19,F21-F23,F25-F27,F29-F31,F33-F35
47插件继电器HK19F-DC 12V-SHG,双刀双掷,8脚pcs8J7,J8,J9,J10,J16,J17,J18,J19
48插件自恢复保险丝GR265-120,265V,120mApcs18R173-R190
49插件轻触按键6*6*7mm,插件pcs1K1
50主板PCBHLC-HUB08 V1.0140*98*1.6mm FR4双面pcs1
51插件针座2Pin,脚距2.54,插件立式pcs1J1
52插件针座5Pin,脚距2.54,插件立式pcs9J2,J3,J4,J5,J6,J12,J13,J14,J15
53排针单排针,脚距2.54,40Pin,立式pcs0.100J21(4pin)
54DC座DC005,外径6.0mm,针2.0mm,卧式,DIPpcs1J20
55螺丝KM3*6mm,镀锌pcs2固定U23,U24
56螺母M3mm,镀锌,外六角pcs2固定U23,U24
重要提示:PCB作品文件展下载说明
pcbjia | 2019-5-28 18:49:47 | 显示全部楼层
PCB 和BOM共享
HUB01.7z (575 KB, 下载次数: 4)
yangxf0120 | 2019-5-28 19:29:48 | 显示全部楼层
谢谢分享门禁开关系统控制板PCB文件
丁响820425 | 2019-5-28 20:26:47 | 显示全部楼层
地沟油 | 2019-5-28 21:18:18 | 显示全部楼层
zhifang88 | 2019-5-28 21:40:19 | 显示全部楼层
cwzdscs | 2019-5-28 22:45:18 | 显示全部楼层
东风导弹 | 2019-5-29 07:07:59 | 显示全部楼层
这个门禁板好像也有点复杂
电子宅 | 2019-5-29 07:55:49 | 显示全部楼层
单枪舞九州 | 2019-5-29 07:59:08 | 显示全部楼层
