[Pads_VX.2x] 再发一个MT6735M 智能手机PCB和原理图共享
查看4869 | 回复49 | 2020-9-26 22:47:27 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalValuePart Type
ANT3301ELJ_DZ_F2POGO PINELJ_DZ_F2
ANT3302ELJ_DZ_F2POGO PINELJ_DZ_F2
ANT3401ELJ_ANTPTH_LTPG-PT0H43-CB01ELJ_ANTPTH_LTPG-PT0H43-CB01ELJ_ANTPTH_LTPG-PT0H43-CB01
B6003L0603BLM18BD252SN1B0603-2500R
BEAD2001L0402BLM15BD102SN1DBEAD-0402
BEAD5001B0402FB / BLM15AG601SN1FB_/_BLM15AG121SN1
BEAD6010L0402BLM15BD102SN1DBEAD-0402
BEAD6200R04020RBEAD-0402
CN6001ELJ_CMUS-06505-097-03KM0004U5P-03-06ELJ_CMUS-06505-097-03
CON1ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3FH26-39S-0.3ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3
CON3301MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATA
CON3302ELJ_RF_MM8030-2610RK0_2X2X1MMKLJ_RF_818000291_2X2X1ELJ_RF_MM8030-2610RK0_2X2X1MM
CON3401ELJ_RF_MM8030-2610RK0_2X2X1MMNC KLJ_RF_818000291_2X2X1ELJ_RF_MM8030-2610RK0_2X2X1MM
CON6002ELJ_ADJ-312-P2.0-3.9X_H4.2ADJ-312-P2.0-3.9X(·´)ELJ_ADJ-312-P2.0-3.9X_H4.2
D2000SOD323/SMD/MM3Z2V4T1PZ3D4V2H (PRISEMI)TVS-6V2-PZ3D4V2H-ROHM
D6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
D6101SOD123MM1Z5VDIODE_SCHOTTKY_2
D6102SOT23_3BAT54SBAT54S
D6103SOD123MM1Z20VDIODE_SCHOTTKY_2
D6108SOT23_3BAT54SBAT54S
D6109SOD1231N5819DIODE_SCHOTTKY_2
D6110SOD1231N5819DIODE_SCHOTTKY_2
EMI6105FILTER/SMD/TCM0806GNCEMIX21A390FNPE_1
H1000PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MM
H1001PTH_HOLE_1.6/2.8MMDNIPTH_HOLE_1.6/2.8MM
J23ELJ-KS270013ELJ-KS270013
J25ELJ_HXQKTS-088_2_4HX-088 2*4ELJ_HXQKTS-088_2_4
J26V30SIM(H3.0MM)ALP-SIMD618-01DUALSIM
J31ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5ELJ_0.5-H1.5-6P_ZIF_6PIN_H1.5
J32ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9NCELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9
J6001ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6003REC_DYS-1506T2332-W01NCREC_DYS-1506T2332-W01
J6006ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6101ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5ELJ_0.5-H1.5-30P_ZIF_30PIN_H1.5
J6102ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3FPC51P-0.3MMELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3
J6502SOCKET-SIM-LK-SIM437-0615RS0DD-180006-01GSOCKET-SIM-LK-SIM437-0615R
J6503ELJ_YHTKP-1915-W_PHS_H1.9YHTKP-1915-CELJ_YHTKP-1915-W_PHS_H1.9
J6601NC-PADX2-1X1.5NCNC-CON-2-0805
J6602NC-PADX2-1X1.5NCNC-CON-2-0805
L3L0201L / 4.7 / nH / 0201L0201
L4L0201L / 4.7 / nH / 0201L0201
L1302L04021.0nH_0.3nHL0402-1N0
L2000L25200.33uH_252012L2520-22U
L2001L/IND/SMD/VLS201610EPL / 0.47 / uH / 2016L/IND/SMD/VLS201610E
L6101MPH252012NRH2410T4R7MNMPH252012
L6103CD4310uHIND-CD43
L6105MPH252012NRH2410T4R7MNMPH252012
LED6201FLASHLED_SMD_EFF-D8CA-POOTFLASH LEDFLASHLED_SMD_EFF-D8CA-POOT
MARK1003MARK_ALLDNIMARK_ALL_A
NTC2000R0402NTCG104EF104FRES0402
NTC3201R0402NTC / NTCG064EF104FR0402-0R
Q6101SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6102SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6103SOT23_3WPM2026IRF5210/TO_6
Q6104SOT23_3MMBT3904NPN_BEC
SH2100KLINK_NO_PAD_0.1MM_LAYER7SHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7
SH6100NC_SHORT_0402NC_SHORT_0402
SHORT1KLINK_NO_PAD_0.1MM_LAYER7AASHORT / NC-MMD-L9-4MILKLINK_NO_PAD_0.1MM_LAYER7
TP_URXD1101TP_1.0TP1.0MM
TP_UTXD1101TP_1.0TP1.0MM
U11ELI-MXC400XXC_6P_17X11.8_H0.9MMELI-MXC400XXC_6P_17X11.8_H0.9MM
U1000MT6735/VFBGA641/P0.4/B0.25/12.6X12.6MT6735MMT6735/VFBGA641/P0.4/B0.25/12.6X12.6
U2001FAN54015FAN54015
U2002MT6328/VFBGA206/P0.4/B0.25/6.6X6.6MT6328V/AMT6328/VFBGA206/P0.4/B0.25/6.6X6.6
U2305CP2155CP2155DN10-A1CP2155
U3002BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBASamsung KLM2G1HE3F-B001BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBA
U3101MT6169/VFBGA175/P0.4/B0.25/6.2X5.4U / MT6169MT6169/VFBGA175/P0.4/B0.25/6.2X5.4
U310226M_VTCXO_2520_2016_T_VVTCXO / 26 / MHz / KT2520F26000DCW28QAK26M_VTCXO_2520_2016_T_V
U3203SKY77643SKY77643/HRSMAC001/RF5410SKY77643
U3215BALUN/SMD/HHM22112A2LPF / LF1608-B2R5KCBBALUN/SMD/HHM22112A2
U3303RF1628SPDT / RF1628ASPDT_/_BGS12SL6_2
U3304DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY806MBA0F0ASAW-DPX-RX-BAL_2
U3306SAW-SAYRF1G73CA0F0A-2016-1814DPX / SAYRF1G95CA0B0AR05SAW-SAYRF1G73CA0F0A-2016-1814
U3307SKY77910SKY77910/HRTXAB008/RF5210SKY77910
U3308SAW-SAYRF1G73CA0F0A-2016-1814DPX / SAYFH2G53CCOFOASAW-SAYRF1G73CA0F0A-2016-1814
U3309SAW-SAYRF1G73CA0F0A-2016-1814SAYFH1G74CA0B0ASAW-SAYRF1G73CA0F0A-2016-1814
U3310FILTER/SMD/TFSL06050915-4108B1LPF / TFSL06050915-4108B1 / NCSAW_0_2
U3311DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY710MBA0F0ASAW-DPX-RX-BAL_2
U3312SAW-SAYRF1G73CA0F0A-2016-1814SAYRF1G88CA0B0AR05SAW-SAYRF1G73CA0F0A-2016-1814
U3313DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY836MBA0F0ASAW-DPX-RX-BAL_2
U3314SAW-SAYRF1G73CA0F0A-2016-1814SAYFH1G74CA0B0ASAW-SAYRF1G73CA0F0A-2016-1814
U3316DUPLEXER/8P/SMD/SAYEY710MBA0F0ADPX / SAYEY897MBG0F0ASAW-DPX-RX-BAL_2
U3318BALUN/SMD/TFSZ06052460-3310A2BAL / TFSZ06050775-3338A1BAL_/_TFSZ06051897-3317A1_2
U3329SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0ASAWFILTER/SMD/SAFFB1G90FB0F0A
U3338BALUN/SMD/TFSZ06052460-3310A2BAL / TDK-TFSZ06052460-3310A2BALUN/SMD/TFSZ06052460-3310A2
U3339BALUN/SMD/TFSZ06052460-3310A2BAL / TDK-TFSZ06052460-3310A2BALUN/SMD/TFSZ06052460-3310A2
U3401SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB2G14FA0F0ASAWFILTER/SMD/SAFFB1G90FB0F0A
U3402SKY13414SP5T / SKY13416IC/SP6T/SKY13416_0
U3404SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB942MFM0F0ASAWFILTER/SMD/SAFFB1G90FB0F0A
U3405SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB1G96FN0F0ASAWFILTER/SMD/SAFFB1G90FB0F0A
U3406SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB1G84FL0F0ASAWFILTER/SMD/SAFFB1G90FB0F0A
U3407SAWFILTER/SMD/SAFFB1G90FB0F0ASAFFB881MFM0F0ASAWFILTER/SMD/SAFFB1G90FB0F0A
U3408SAWFILTER/SMD/F6QB2G595P2BSSAW / B9898SAWFILTER/SMD/SAFFB1G90FB0F0A
U3412SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB710MAA0F0ASAWFILTER/SMD/SAFFB1G90FB0F0A
U3413SAWFILTER/SMD/SAFFB1G90FB0F0ASAW / SAFFB806MAA0F0ASAWFILTER/SMD/SAFFB1G90FB0F0A
U3414FILTER/SMD/TFSL06050915-4108B1LPF / TFSL06050915-4108B1 / NCSAW_0_2
U3468BALUN/SMD/TFSZ06052460-3310A2BAL / TFSZ06050775-3338A1BAL_/_TFSZ06051897-3317A1_1
U3474RF1628SPDT / RF1628ASPDT_/_BGS12SL6_2
U4001FBGA220/P0.5/B0.27/14X14/K3PE0E000A/SAMFBGA220/P0.5/B0.27/14X14/K3PE0E000A/SAM
U5101MT6625/SQFN40/SMD/P0.4/5X5U / MT6625L / QFN40MT6611_SMD_WLCSP-61_0
U5102SAFEB1G57KE0F00SAFEB1G57KE0F00IC-SAW-SAFEB1G57KE0F00-MURATA
U5103MAX2659MAX2659ELTIC-GPS-LNAP-MAX2659-MAXIM
U5104KLJ_TPX205950MT-7110A1_1.1X2X0.9TRPX / TDK TPX205950MT-7110A1KLJ_TPX205950MT-7110A1_1.1X2X0.9
U5105SAW-1411FBAR / ACPF-7124SAFEB1G57KA0F00
U6103SOT23_6CP2121ST-B2/TCS23352AP3031_0
U6105SOT23_5WD1013EA/TCS4150-ETCS4150-E
U6109SOT23_6EUP2530/CP2123ST-B1AP3031_0
U6305CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMCLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MM
U6401M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7M-SENSOR-MMC3516XPJ_1.6X1.6_H0.7
U6402STK3171STK3171STK3171
U6403TLE4917-TSOP-6-2OCH167TWADTLE4917
U6404BMA250BMA223IC-3-A-ACCELEROMETER-BMA250-BOSCH
U6705GSL915GSL915
VR2001R0402SFI0402-180E10RPP-LFVR0402
VR2002R0402SFI0402-180E10RPP-LFVR0402
VR2003SOD323/SMD/MM3Z2V4T1NC PTVSHC3D4V5BPTVSHC3D4V5B
VR6000MLV0402SFI0402-180E10RPP-LFVAR_0402
VR6001MLV0402SFI0402-180E10RPP-LFVAR_0402
VR6002ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR6003ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR6004R0402SFI0402-180E10RPP-LFVR0402
VR6005R0402SFI0402-180E10RPP-LFVR0402
VR6006R0402EZJZ0V500AAVR0402
VR6007R0402EZJZ0V500AAVR0402
VR6010MLV0402SFI0402-180E10RPP-LFVAR_0402
VR6011R0402NCVR0402
VR6012R0402NCVR0402
VR6015R0402SFI0402-180E10RPP-LFVR0402
VR6026ESD5641D07NC ESD5641D07ESD5641D07
VR6504R04020_5%VR0402
VR6505R0402SFI0402-180E10RPP-LFVR0402
VR6516R0402EZJZ0V500AAVR0402
X2000CRYS/SMD/3.2X1.5/9H032000XX/TXCNC 32.768KHz¡À20ppmCRYS/SMD/3.2X1.5/9H032000XX/TXC
X510126M_TCXO_2520TC7L26002015_2016L26421NC TCXO / 26 / MHz / IT2205AE26M_TCXO_2520TC7L26002015_2016L26421
重要提示:PCB作品文件展下载说明
hbjsss | 2020-9-26 22:48:04 | 显示全部楼层
老吴 | 2020-9-26 22:49:59 | 显示全部楼层
PCB 原理图都是PADS格式。一起打包。全网首发,5RMB 。有需要的下载。
MT6735M_PCB&SCH.7z (2.9 MB, 下载次数: 7)
cityhu | 2020-9-27 00:23:49 | 显示全部楼层
longxuekai | 2020-9-27 05:51:02 | 显示全部楼层
kanxue_nmg | 2020-9-27 07:54:05 | 显示全部楼层
love欣 | 2020-9-27 08:00:13 | 显示全部楼层
wangy2000 | 2020-9-27 08:02:46 | 显示全部楼层
bidinghong | 2020-9-27 08:13:17 | 显示全部楼层
bee13530816634 | 2020-9-27 08:24:00 | 显示全部楼层
