[Pads_VX.2x] 独家首发-MT8765 做的智能手机PCB和原理图
查看3747 | 回复17 | 2020-9-30 11:05:10 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePCB DecalValuePart Type
ANT3301ELJ_SOLDERING_ANTPADELJ_SOLDERING_ANTPAD
ANT3401ELJ_M08M001-G0G000-WA035R_TP_H3.5_W3.0POGO PINELJ_M08M001-G0G000-WA025R_W1.2L2.7H2.5
BEAD6104B0603UPZ1608U221-2R2TFB0603-75R
CON3301MM4829-2702BMHC-310CON-RF-TEST-MM4829-2702B-MURATA
CON3302ELJ_RF_MM8030-2610RK0_2X2X1MMKLJ_RF_818000291_2X2X1ELJ_RF_MM8030-2610RK0_2X2X1MM
CON3401ELJ_RF_MM8030-2610RK0_2X2X1MMNC KLJ_RF_818000291_2X2X1ELJ_RF_MM8030-2610RK0_2X2X1MM
CON4101ELJ_J-TF-521-F_TF-FCB0.9YHTKP-1915-CELJ_J-TF-521-F_TF-FCB0.9
D2000SOD323/SMD/MM3Z2V4T1PZ3D4V2H (PRISEMI)TVS-6V2-PZ3D4V2H-ROHM
D6001ELJ_TVSESD9X5VL-2_SOD-923_H0.45TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
D6201SOD1231N5819DIODE_SCHOTTKY_2
D6202SOD1231N5819DIODE_SCHOTTKY_2
D6203SOD1231N5819DIODE_SCHOTTKY_2
D6204SOD1231N5819DIODE_SCHOTTKY_2
D6205SOT23_3BAT54SBAT54S
D6206SOT23_3BAT54SBAT54S
D6801SOD1231N5819DIODE_SCHOTTKY_2
EMI6601FILTER/SMD/TCM0806GNCEMIX21A390FNPE_1
ESD5001ELJ_TVSESD9X5VL-2_SOD-923_H0.45NC ESD5301NELJ_TVSESD9X5VL-2_SOD-923_H0.45
FB2201BEAD0402FB / BLM15HG102SN1FB_/_BLM15HG102SN1
J2ELJ-KS270013ELJ-KS270013
J2601ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9BAT-5PIN-1.25JP-H1.9ELJ-BAT1254001-05YZ_5PIN-1.25JP-H1.9
J2602NC_BAT_CON_3NCNC_BAT_CON_3
J3301ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0
J6001ELJ_ADJ-312-P32-39X_EAR-CB3.2-H4.2ELJ_ADJ-312-P32-39X_EAR-CB3.2-H4.2ELJ_ADJ-312-P32-39X_EAR-CB3.2-H4.2
J6002ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NC ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6003ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NC ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6101ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NC ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6102ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NC ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6201ELJ_FH26-45S-0.3SHW_ZIF_PH0.6_H1.0ELJ_L50124_45PIN_0.5PJ_H2.0ELJ_FH26-45S-0.3SHW_ZIF_PH0.6_H1.0
J6302ELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3AXK7L30227GELJ_FH26-39S-0.3SHW_PH0.6-FPC0309-39B3
J6601ELJ_MROF-150205-05GS_USB-CB1.0KM0004U5P-03-06ELJ_MROF-150205-05GS_USB-CB1.0
J6701ELJ_YHSIM-SIM07X-005_SIM-FCB-1.05S0DD-180006-01GELJ_YHSIM-SIM07X-005_SIM-FCB-1.05
J6702ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0
J6703FPCPAD_6PIN_PH0.8NCFPCPAD_6PIN_PH0.8
J6704ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0ELJ_HC503-6R-GF_PJ_0.5_H1.0
J6705FPCPAD_6PIN_PH0.8NCFPCPAD_6PIN_PH0.8
J6801ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85NC ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85ELJ_BAR080T028-NYZ_2P-0.8JP-H1.85
J6802NC-PAD_2PIN_1.3X1.8NCNC-PAD_2PIN_1.3X1.8
J9002ELJ_HC503-6R-GF_PJ_0.5_H1.0HC503-6R-GFELJ_HC503-6R-GF_PJ_0.5_H1.0
J9003ELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3NC FPC51P-0.3MMELJ_FH26-51S-0.3SHW_PH0.6-FPC0309-51B3
L2610L/IND/SMD/25201uHL/IND/SMD/2520
L6201LCDBACKLIGHT_L_4_4SWPA4018S100MTELLVFG-C_1.4_3.2
L6202MPH252012NRH2410T4R7MNMPH252012
L6203MPH252012NRH2410T4R7MNMPH252012
L6802SQC322517HP-220M-N10uHIND-POWER-22UH-SQC322517HP-220M-N
MARK1003MARK_ALLDNIMARK_ALL_A
NTC3201R0402NTCG104EF104FRES0402
NTC6401R0402NTCG104EF104FRES0402
PL2001L2520WPN252012HR47MTL2520-2U2
Q6201SOT23_3WPM2026IRF5210/TO_6
Q6202SC-75_SOT-416_DTC114EET1-DDTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6203WNM4002_SOT-523/723WNM4002WNM4002_SOT-523/723
Q6204WNM4002_SOT-523/723WNM4002WNM4002_SOT-523/723
Q6301SC-75_SOT-416_DTC114EET1-DNC DTC114YET1SC-75_SOT-416_DTC114EET1-D
Q6801WNM4002_SOT-523/723NC WNM4002WNM4002_SOT-523/723
Q6802WNM4002_SOT-523/723WNM4002WNM4002_SOT-523/723
Q6803SOT23_3WPM2026IRF5210/TO_6
Q6804WNM4002_SOT-523/723NC WNM4002WNM4002_SOT-523/723
Q6805SC-75_SOT-416_DTC114EET1-DDTC114YET1SC-75_SOT-416_DTC114EET1-D
RJ212NC_SHORT_0402NCNC_SHORT_0402
RXD0TP_1.2NFTP_1.2
RXD1TP_1.2NFTP_1.2
SH1003NC/MMD/L1/4MILNC/MMD/L1/4MILNC/MMD/L1/4MIL
SH2009NC/MMD/L2/4MILSHORT / NC-MMD-L1-4MILNC/MMD/L2/4MIL
TXD1TP_1.2NFTP_1.2
U1001MT8765/VFBGA491/P0.4/B0.25/11.8X11MT8765MT8765_LPDDR3_DSC
U2001MT6357/VFBGA209/P0.4/B0.25/7.0X6.6MT6357MT6357/VFBGA209/P0.4/B0.25/7.0X6.6
U2601FAN54015FAN54015FAN54015
U3101MT6177M/VFBGA120/P0.4/B0.25/5.0X4.6MT6177MV/BCA-HMT6177M/VFBGA120/P0.4/B0.25/5.0X4.6
U3203SKY77643SKY77643/HRSMAC001/RF5410SKY77643
U3214SAFEA2G60MA0F0ANC SAFEA2G60MA1F0ASAFEA2G60MA0F0A
U3215BALUN/SMD/HHM22112A2LPF / LF1608-B2R5KCBBALUN/SMD/HHM22112A2
U3301RFLPF16080G9D7TRFLPF16080G9D7TRFLPF16080G9D7T
U3302SAW/8P/SMD/SAYEY1G95GA0F0ADPX / D5DA737M5K2H2DPX_/_D5DA737M5K2H2
U3303RF1628SPDT / RF1628ASPDT_/_BGS12SL6_2
U3304RFBPF16081G9DMAT73RFBPF16081G9DMAT73RFBPF16081G9DMAT73
U3305SAW/8P/SMD/SAYEY1G95GA0F0ADPX / D6HQ2G655DP02DPX_/_D6HQ2G655DP02
U3306SAW/8P/SMD/SAYEY1G95GA0F0ADPX / D6DA2G132K2D4DPX_/_D6DA2G132K2D4
U3307SKY77910SKY77910/HRTXAB008/RF5210SKY77910
U3308SAW/8P/SMD/SAYEY1G95GA0F0ADPX / D6DA2G140K2A4DPX_/_D6DA2G140K2A4
U3309SAW/8P/SMD/SAYEY1G95GA0F0ADPX / D6DA1G960K2B2DPX_/_D6DA1G960K2B2
U3310SAW/8P/SMD/SAYEY1G95GA0F0ADPX / D5DA942M5K2S2DPX_/_D5DA942M5K2S2
U3311SAW/8P/SMD/SAYEY1G95GA0F0ADPX / D6DA1G842K2C4DPX_/_D6DA1G842K2C4
U3313SAW/8P/SMD/SAYEY1G95GA0F0ADPX / D5FC847M0K3NEDPX_/_D5FC847M0K3NE
U3314SAWFILTER/5P/SMD/SAFFB2G14AA0F0AF6QA2G350M2QASAW_/_F6QA2G655M2QH
U3315SAFEA2G60MA0F0ASAFFB2G60AA1F0ASAFEA2G60MA0F0A
U3317FILTER/6P/SMD/1005LPF/TDKLPF / FI 105L0829GZLPF_/_FI_105L0829GZ
U3402SKY13414SP5T / SKY13416IC/SP6T/SKY13416_0
U3404SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / F5QA737M5M2QNSAW_/_F5QA737M5M2QN
U3405FILTER/6P/SMD/1005LPF/TDKLPF / FI 105L0829GZLPF_/_FI_105L0829GZ
U3406SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / F5QA806M0M2QESAW_/_F5QA806M0M2QE
U3407RF1628SPDT / RF1628ASPDT_/_BGS12SL6_2
U3408RFLPF16080G9D7TRFLPF16080G9D7TRFLPF16080G9D7T
U3409RFBPF16081G9DMAT73RFBPF16081G9DMAT73RFBPF16081G9DMAT73
U3410SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / F6QA2G140M2AMSAW_/_F6QA2G140M2AM
U3411SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW /F6QA2G350M2QASAW_/_F6QA2G655M2QH
U3412SAWFILTER/5P/SMD/SAFFB2G14AA0F0ASAW / F6FC2G600H4PASAW_/_F6FC2G600H4PA
U4001FBGA178/SMD/B0.4/3-IN-1LPDDR3 178bFBGA178/SMD/B0.4/3-IN-1
U4201BGA169/P0.5/B0.27/THGBM1GXDXEBAI/TOSHIBAQVL Memory169_BALL_EMMC_1
U5001MT6625/SQFN40/SMD/P0.4/5X5MT6625LU_/_MT6625LN_/_AME-PEGA-L
U5002SAW-1411FBAR / ACPF-7124SAFEB1G57KA0F00
U5003KLJ_TPX205950MT-7110A1_1.1X2X0.9TRPX / TDK TPX205950MT-7110A1KLJ_TPX205950MT-7110A1_1.1X2X0.9
U5004MAX2659MAX2659ELTIC-GPS-LNAP-MAX2659-MAXIM
U5005SAFEB1G57KE0F00SAFEB1G57KE0F00R15IC-SAW-SAFEB1G57KE0F00-MURATA
U6101AW8145CSRAW8155AFCRAW8145CSR
U6102AW8145CSRAW8155AFCRAW8145CSR
U6201SOT23_6EUP2530/CP2123ST-B1AP3031_0
U6202SOT23_5WD1012EA/TCS4150-ETCS4150-E
U6203SOT23_6CP2121ST-B2/TCS23352AP3031_0
U6205SOT23-5WL2003E18WL2003E
U6301CP2155CP2155DN10-A1CP2155
U6302SOT23-5WL2003E28WL2003E
U6401MMC3630KJMMC3630KJMMC3630KJ
U6402CLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MMCLI_MPU5400_GYROSCOPE_0.4PTH_3X3X0.9MM
U6403TLE4917-TSOP-6-2OCH168TWADTLE4917-TSOP-6-2
U6404BMA250BMA223IC-3-A-ACCELEROMETER-BMA250-BOSCH
U6405EPL21822STK3171EPL21822
U6801CSP16/SMD/P0.4/B0.25/TPS6128X/SFPF3040WLCSP16/SMD/P0.4/B0.2/FPF3040
U6802SOT23_6CP2121ST-B2AP3031_0
U9001ELI_GSL3676_QFN56_7X7X1_TPICNCGSL3676
VR2601R0402SFI0402-180E10RPP-LFVR0402
VR2602R0402SFI0402-180E10RPP-LFVR0402
VR2606SOD323/SMD/MM3Z2V4T1NC ESD56131WPTVSHC3D4V5B
VR4101R0402NCVR0402
VR6004MLV0402SFI0402-180E10RPP-LFVAR_0402
VR6006R0402NC SFI0402-180E10RPP-LFVR0402
VR6104R0402NC EZJZ0V500AAVR0402
VR6601MLV0402SFI0402-180E10RPP-LFVAR_0402
VR6602MLV0402SFI0402-180E10RPP-LFVAR_0402
VR6603ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR6605ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45ELJ_TVSESD9X5VL-2_SOD-923_H0.45
VR6606ESD5641D07NC ESD5641D07ESD5641D07
VR6701R0402SFI0402-180E10RPP-LFVR0402
VR6801ESD5641D07NC ESD5641D07ESD5641D07
VR6802MLV0402ESD9B5V-2/TRVAR_0402
WR6201VR2X2NC 1KVR2X2
X220126M_TCXO3225_2520_7M26000028_DSA26MHz  / 7M2600002826M_TCXO3225_2520_7M26000028_DSA
X500126M_TCXO_2520TC7L26002015_2016L26421NC TCXO / 26 / MHz / IT2205AE26M_TCXO_2520TC7L26002015_2016L26421
重要提示:PCB作品文件展下载说明
老吴 | 2020-9-30 11:07:41 | 显示全部楼层
独家首发资料。MT8765的资料网上根本找不到。请勿转载。 10RMB 有需要的下载。
MT8765_pcb&sch.7z (3.02 MB, 下载次数: 8)
主板狂魔 | 2020-9-30 11:41:11 | 显示全部楼层
老吴 | 2020-9-30 11:42:37 | 显示全部楼层
bidezhi7777 | 2020-9-30 12:07:01 | 显示全部楼层
bingo426 | 2020-9-30 12:50:45 | 显示全部楼层
最后成功的人往往不是最有才华的人,而是那些默默付出直到最后一刻也不放弃的那些人!
单枪舞九州 | 2020-9-30 13:39:46 | 显示全部楼层
luchonghui74 | 2020-9-30 14:38:37 | 显示全部楼层
拾柒2019 | 2020-9-30 15:15:49 | 显示全部楼层
fengxz | 2020-9-30 16:33:49 | 显示全部楼层
MT8765 做的智能手机PCb
