重要提示:PCB作品文件展下载说明
和前几天发的1v2 版本,主要差别就是上图圆圈位置。1V2版 http://bbs.ntpcb.com/read-htm-tid-164762.html
Name | Part Type | PCB Decal | Value | BAT1 | MS621FEFL11E | MS621FEFL11E | NC(MS621FEFL11E) | CE1 | 470UF_25V_20%_LESR | EC_3P5_8P0 | 470uF | CM3 | 1UF_10V_10%_SMD0402_3 | C0402 | 1uF | CM4 | 1UF_10V_10%_SMD0402_3 | C0402 | 1uF | CM6 | 1UF_10V_10%_SMD0402_2 | C0402 | 1uF | CN1 | SD_SOCKET_TOP_A_PANASONIC | SD_STANDARD_A | SD_Socket_Top_A_Panasonic | CN2 | USB_A_RECEPTACLE_SMD_4P | CN_USB_A | USB_A_SMD | CON1 | HDMI_M_0 | CN_HDMI_19_050_ | CON/HDMI | CT1 | 47UF_6.3V_20%_B_CASE | CAP_B_3528 | 47uF,6.3V | CW16 | 0.01UF_50V_20%_SMD0402 | C0402 | 0.01uF | D1 | RB551V-30_SOD323 | SOD323 | RB551V-30 | D2 | RCLAMP0520B_SOT-523 | RCLAMP0502B | NC(RClamp0520B) | FB25 | FB/0805 | L0805 | FB/0805 | J1 | 1X8P_MALE_DIP_2.0 | SIP_8P_200 | NC(1X8P_2.0M) | J2 | 1X8P_MALE_DIP_2.0 | SIP_8P_200 | NC(1X8P_2.0M) | J3 | RJ45_0 | RJ45_PA6T | RJ45 | J4 | 2X22P_FEMALE_DIP_1.27 | CN22X2_127 | NC(2X22P_1.27F) | J5 | 2X20P_FEMALE_DIP_2.0 | CN20X2_200 | 2X20P_2.0F | J6 | RCA_JACK_90D_YELLOW_DIP_2P | RCA_JACK | RCA_Yellow | J7 | 1X2P_MALE_DIP_1.27 | JP2_125_I | 1X2P_1.25M | J8 | 2X20P_FEMALE_DIP_2.0 | CN20X2_200 | 2X20P_2.0F | J9 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J10 | 1X5P_MALE_DIP_2.54 | SIP_5P | 1X5P_2.54M | J11 | 2X10P_MALE_DIP_1.27 | CN10X2_127 | 2X10P_1.27M | J12 | 1X4P_MALE_DIP_2.54 | SIP_4P | 1X4P_2.54M | J13 | DC_JACK | PJ20_3P | DC_JACK | J14 | 1X2P_MALE_DIP_2.0 | SIP_2P_200 | 1X2P_2.0M | J15 | 2X15P_MALE_2LAYER_DIP_2.0 | CN15X2_200 | 2X15P_2.0M_2L | J16 | 1X2P_FEMALE_DIP_2.0 | SIP_2P_200 | 1X2P_2.0M | L1 | 4.7UH_4.2A_20%_SMD_SB0805 | L_SB0805 | 4.7uH | L2 | 2.2UH_1.85A_20%_SMD_SR0302 | L_SR0302 | 2.2uH | L3 | 2.2UH_1.85A_20%_SMD_SR0302 | L_SR0302 | 2.2uH | L4 | 2.2UH_1.85A_20%_SMD_SR0302 | L_SR0302 | 2.2uH | LED3 | RED__SMD0603 | LED0603 | RED | LED4 | GREEN__SMD0603 | LED0603 | GREEN | MIC1 | MIC-MICROPHONE0 | MIC | MIC-EM5BPS | PB2 | PUSH_BOTTOM_BLUE_SMD_2P | SW_SMD_2P | KEY1 | RP20 | 33_1/16W_5%_8P4R | RP_4 | NC(33) | RP22 | 22_1/16W_5%_8P4R_0402 | RP_4_0402 | 22 | RP23 | 22_1/16W_5%_8P4R_0402 | RP_4_0402 | 22 | SW1 | SWITCH_4_PORT_SMD_8P | SW_HDS404 | SW_SMD | SW2 | SWITCH_2_PORT_SMD_4P | SW_HDS402 | SW_SMD | SW3 | SWITCH_4_PORT_SMD_8P | SW_HDS404 | SW_SMD | SW4 | SW_SPDT3_DIP | SW_SPDT3_1 | SW-SPDT3 | SW5 | SWITCH_4_PORT_SMD_8P | SW_HDS404 | SW_SMD | U1 | GM8138_EPAD_LQFP176_SKT_7 | QFP176_040+EPAD | GM8138_EPAD_LQFP176_SKT | U3 | K4B2G1646B-HCK0-1600 | DDR3_FBGA_X16_9X13P3 | K4B2G1646B-HCK0-1600_2G(128Mx16) | U6 | W25P80/16 | SOIC8_208 | M25P32 SO8 | U7 | SPI_FLASH_SOP16 | SOP16_300 | NC(SPI_FLASH,SOP16) | U8 | K9F1G08U0B(128MBX8)_TSOP48_0 | TSOP48_12X20 | NAND FLASH K9F1G08U0B(128Mbx8) | U9 | G5250C1T1U | SOT25 | NC(G5250C1T1U) | U10 | IP101GR | TQFN32_040+EPAD | IP101GR | U11 | H1102_1 | TS8121C | TS8121C | U12 | CAT6612_0 | QFP80_050 | IT6612 | U13 | G9131-18T73UF | SOT23 | G9131-18T73Uf | U14 | AKU2002C | MIC_AKU2002C | AKU2002C | U15 | AKU2002C | MIC_AKU2002C | AKU2002C | U16 | IR_0 | ECM_A38_N3 | IRM3638T,3.3V | U17 | MP1484_SOP8_0 | SOP8+EPAD | MP1482,SOP8 | U18 | G9131-28T73UF_ | SOT23 | G9131-28T73Uf | U19 | G5699_0 | TDFN12_045_3X3 | G5699 | U20 | G9131-18T73UF | SOT23 | G9131-18T73Uf | U21 | G5628ADJT1U_SOT25 | SOT25 | G5628 | U22 | DS1307_SOIC8 | SOIC8_150 | NC(PT7C4307,SOIC8) | Y1 | 12MHZ_OSC_30PPM_SMD5X3_0 | XTAL_SMD_50X32 | 30MHz |
| | | | Y3 | 32.768KHZ_CRY_30PPM_SIZE_2X6 | XTAL_0P7L | NC(32.768KHz) |
重要提示:PCB作品文件展下载说明
