[其他器件] Nano_Socket_iWiFi_DS
查看456 | 回复1 | 2016-6-8 08:47:30 | 显示全部楼层 |阅读模式
Hardware Description
ƒ Size: 45.21 x 24.88 x 8.6 mm
ƒ Core CPU: Connect One CO2144 running at 48MHz
ƒ Operating Voltage: +3.3V+/-10%
ƒ Operating Humidity: 90% maximum (non-condensing)
ƒ Operating Temperature Range: -20° to 75°C (-4° to 167°F)
ƒ Power Consumption:
Transmit –
   250mA @16dbm
  235mA @12dbm (typical)
Receive – 190mA (typical)
Power Save mode – 8mA
ƒ On-Board 2dBi Antenna
ƒ Connector: 2 x 15 Header 2mm pitch
ƒ Host Interface: TTL Serial, SPI and
USB device.
ƒ RMII Interface
ƒ RoHS-compliant; lead-free
Nano_Socket_iWiFi_DS.pdf (430 KB, 下载次数: 0)
chinatiger11 | 2016-6-8 09:10:23 | 显示全部楼层
