Nano_WiReach_SMT_MAX_DS-1_01
Hardware Description
Size: 37.0 x 20.0 x 3 mm
Core CPU: 32-bit RISC ARM7TDMI, lowleakage, 0.13 micron, running at 48MHz
Operating Voltage: +3.3V+/-10%
Operating Humidity: 90% maximum (noncondensing)
Operating Temperature Range:
-30° to 85°C (-31° to 185°F)
Power Consumption(maximum):
Transmit – 300mA @16dbm
Receive – 300mA (typical)
Power Save mode – 7mA
Optional : On-Board antenna
Optional: U.FL connector
Connection: 44 SMT pads
Host Interface: TTL Serial, SPI and USB Full
Speed 2.0 device.
A/D Input (see AT+I programmers manual)
Cellular Modem Interface: USB 2.0 Full Speed
Host
10/100BaseT LAN Interface: RMII (w/ext.
PHY)
RoHS-compliant; lead-free
Nano_WiReach_SMT_MAX_DS-1_01.pdf
(4.76 MB, 下载次数: 0)
