[IC] ds_k4h281638l_rev12-0
查看379 | 回复0 | 2016-6-29 08:59:04 | 显示全部楼层 |阅读模式
128Mb L-die DDR SDRAM Specification
• VDD : 2.5V ± 0.2V, VDDQ : 2.5V ± 0.2V for DDR333, 400
• VDD : 2.5V ± 5%, VDDQ : 2.5V ± 5% for DDR500
• Double-data-rate architecture; two data transfers per clock cycle
• Bidirectional data strobe [L(U)DQS] (x16)
• Four banks operation
• Differential clock inputs(CK and CK)
• DLL aligns DQ and DQS transition with CK transition
• MRS cycle with address key programs
-. Read latency : DDR333(2.5 Clock), DDR400(3 Clock), DDR500(3 Clock)
-. Burst length (2, 4, 8)
-. Burst type (sequential & interleave)
• All inputs except data & DM are sampled at the positive going edge of the system clock(CK)
• Data I/O transactions on both edges of data strobe
• Edge aligned data output, center aligned data input
• LDM,UDM for write masking only (x16)
• Auto & Self refresh
15.6us refresh interval(4K/64ms refresh)
• Maximum burst refresh cycle : 8
• 66pin TSOP II Lead-Free and Halogen-Free package
• RoHS compliant
ds_k4h281638l_rev12-0.pdf (485 KB, 下载次数: 0)
