[PADS9.5以下] 展讯SC7731G +GSL168X+SR3131+SKY77592+SR2351C+SR2319A 通话平板PCB和原
查看12628 | 回复56 | 2017-3-2 22:43:19 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
NamePart TypePCB DecalValue
ANT1ANTENNA_BTANTENNA2SMA
ANT0005CON-SPRING-CM1406-180CON-SPRING-CM1406-180
ANT0006CON-SPRING-CM1406-180CON-SPRING-CM1406-180
D1D-MBR0530TXSOD-123MBR0540
D0002DIODE-SCHOTTKY-WSB5503W-2/TRSOD-323
D0300DIODE-SCHOTTKY-WSB5503W-2/TRSOD-323
D0301DIODE-SCHOTTKY-WSB5503W-2/TRSOD-323
D4102DIODE-SWITCH-LBAT54SLT1GSOT23
D4103DIODE-SWITCH-LMBR140T1GSOD-323_3
D4104DIODE-ZENER-UDZS16BUMD2
D4105DIODE-SWITCH-LBAT54SLT1GSOT23
D4107DIODE-ZENER-UDZV6.8BUMD2
D6201DIODE-LED-WHITE-0603_1LED4
FB1BEAD-470-OHM-100MHZ-0.5A-0603402470ohm@100MHz 500mA
FB4200BEAD-1K-OHM-100MHZ-250MA-0201RC0201_31000ohm@100MHz
FD6201NC-FIDUCIALMARKPAD-FID
FD6202NC-FIDUCIALMARKPAD-FID
FD6203NC-FIDUCIALMARKPAD-FID
FD6204NC-FIDUCIALMARKPAD-FID
J1NC-PAD-1.5X2NC-PAD-1.5X2
J2SOCKET-T-CARDSD_F03
J222CMP_395CMP_395
J3100CON-EAR-KJ-366CN-L3PHONE6140822 DT?yí?ê?′í?ó
J4101CON-FPC-FPC30-LCDCON-FPC-FPC30-T1T12021-AYQL7021D01H
J4201CON-FPC-FPC30-T1T1-2021-ACON-FPC-FPC30-T1T12021-A
J5100CON-FPC-FPC24CON-FPC-FPC24
J6100NC-PAD-1.5X2NC-PAD-1.5X2
J6101NC-PAD-1.5X2NC-PAD-1.5X2
J6201CON-USB-MICRO-CBCON-USB-MICRO-CB
J6401SOCKET-SIM-WKSM018-3001SOCKET-SIM-SIM25-16M03-TP300
L1CAP-33PF-0402RC020133PF
L0300IND-POWER-2.2UH-SPH252012H2R2MTIND-POWER-MPH20162.2uH
Q4100TRIODE-NPN-2SC5658VMT3
Q6203MOSFET-N_SOT-723_WNM2030SOT723WNM2030
REC3100AUDIO-RECEIVER-SDRP0612KJ02-F1-GAUDIO-RECEIVER-SDRP0612KJ02-F1-G
S6300SWITCH-PUSH-ST-1114RSWITCH-PUSH-TS-1100A
TP6200NC-TP-JTAG-10PINNC-TP-JTAG-10PIN
TVS3100TVS-ESD9L5.0ST5GTVS-ESD9L5.0ST5G
TVS6100TVS-ESD5Z3.3T1G-3.3V-105PF-SOD-523SOD-523
TVS6101DIODE-ZENER-PZ3D4V2HSOD-323-PRISEMI
TVS6202TVS-ESD5Z7.0T1GSOD-523
U1POWER-LDO-RT9193-33GU5SC70-51.8V
U2FET-P-SI2301CDS-T1-GE3SOT23
U16LPW5206HSOT25TCS9322
U23G5121_1SOT26WD3126
U45GSL168X_1QFN_5X5MM_40NC/GSL168X
U0100ASIC-SC7731G-597-0.4BGA12.1X13.3-597-0.4-SC7731G
U0303POWER-DC2DC-MP3221GJSOT23-63V-6V
U0304FET-P-SI2301CDS-T1-GE3SOT23
U0401RF-SAW-B39881-B9400-K610RF-SAW-B39881-B9400-K610
U0402RF-SAW-DPX-B8558RF-SAW-2.0X1.6
U0403RF-SAW-DPX-B8078RF-SAW-2.0X1.6
U0404RF-SW+PA-SKY77592RF-SW+PA-SKYWORKS-6X6-28PIN
U0405RF-TRANSCEIVER-SR3131RF-TRANSCEIVER-SR3131
U0406RF-PA-SKY77761RF-PA-SKYWORKS-3X3-10PIN
U0407RF-PA-SKY77762RF-PA-SKYWORKS-3X3-10PIN
U0408RF-SAW-SAWEN1G84CV0F00RF-SAW-SAWEN1G84CV0F00
U0409RF-PA-SKY77768RF-PA-SKYWORKS-3X3-10PIN
U0410RF-SAW-DPX-B8072RF-SAW-2.0X1.6
U0501MEM-LPDDR3+EMMC-KMQ7X000SA-B315BGA11.5X13-221-0.5
U3100AUDIO-AMP-AW8110WCSP9
U4108G5121SOT26TCS8254
U4109G5121SOT26TCS5525-F
U5200SENSOR-MOTION-LIS3DHSENSOR-MOTION-LIS3DH
U5201AV02-3190_1LTR-533JSA-1213
U6104POWER-CHARGER-FAN54015UCXPOWER-CHARGER-FAN54015UCX
U7200POWER-LDO-WL2801E33-5/TRSOT23-53.3V(NF)
U7202RF-SAW-SAFEA1G57KE0F00RF-SAW-1.35X1.05
U7203RF-SW+PA-2.4G-SR2319ASR2319A
U7204RF-LNA-GPS-BGU7005RF-LNA-GPS-BGU7005
U7206BT+WIFI+FM+GPS-SR2351CBT+WIFI+FM+GPS-SR2351
U7207LOGIC-GATE-BUFFER-SN74AUC1G125DCKRSC70-5(NF)
U7209LFD211G58DPFC268_0LFD181LFD211G58DPFC268
U7252RF-SAW-LFB212G45CL1D172RF-SAW-LFB212G45CL1D172
U8001GS1013CMP_513KXCJK_1013
UART1UART00UART1
X0200XTAL-CRYSTAL-32.768K-Q-SC32S0322070AAAFXTAL-CRYSTAL-SCX321532.768KHz
X0400XTAL-CRYSTAL-E3SB26.0000F09G11CRYSTAL-26M26MHz
X7200XTAL-TCXO-26MHZ-1XTW26000CCAXTAL-TCXO-26MHZ-1XTW26000CCA26MHz
重要提示:PCB作品文件展下载说明
手机开发 | 2017-3-2 22:46:13 | 显示全部楼层
板子还有一些没画完, PCB 和原理图 和结构图都有。有兴趣练习的可以下载看看。
SC7731G_DXF.zip (371 KB, 下载次数: 7)
xiaoxiao | 2017-3-3 00:03:31 | 显示全部楼层
o桃花岛主o | 2017-3-3 06:31:42 | 显示全部楼层
学海无涯 | 2017-3-3 06:51:01 | 显示全部楼层
altim | 2017-3-3 08:05:16 | 显示全部楼层
linyuanfei | 2017-3-3 08:08:29 | 显示全部楼层
longxuekai | 2017-3-3 08:19:51 | 显示全部楼层
kbh2006@163.com | 2017-3-3 08:20:09 | 显示全部楼层
yerik | 2017-3-3 08:31:26 | 显示全部楼层
社区居民忠实会员终身成就奖宣传大使奖
