[Allegro16.6以下] nRF52832-QFAA-R+KX022-1020+AT25SF081-MAHD-T 蓝牙小板PCB文件
查看7169 | 回复18 | 2017-9-16 09:26:45 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
C1CAP NP_C0402_4.7UF4.7uFC0402
C2CAP NP_C0201_12PF12pFC0201
C3CAPNP_C0402_4.7UF/10V4.7uF/10VC0402
C4CAP NP_C0201_0.1UF0.1uFC0201
C5CAP NP_C0201_20PF20PFC0201
C6CAPNP_C0402_2.2UF/16V2.2uF/16VC0402
C7CAPNP_C0402_2.2UF/16V2.2uF/16VC0402
C8CAP NP_C0201_0.1UF0.1uFC0201
C9CAP NP_C0201_20PF20PFC0201
C10CAP NP_C0201_12PF12pFC0201
C11CAP NP_C0201_100PF100pFC0201
C12CAP NP_C0201_NCNCC0201
C13CAP NP_C0201_0.1UF0.1uFC0201
C14CAP NP_C0201_0.1UF0.1uFC0201
C15CAP NP_C0201_12PF12pFC0201
C16CAP NP_C0201_0.8PF0.8pFC0201
C17CAP NP_C0201_NCNCC0201
C18CAP NP_C0603_22UF22uFC0603
C19CAP NP_C0201_0.1UF0.1uFC0201
C20CAP NP_C0402_4.7UF4.7uFC0402
C21CAP NP_C0603_10UF10uFC0603
C22CAP NP_C0201_22PF22PFC0201
C23CAP NP_C0201_0.1UF0.1uFC0201
C24CAP NP_C0201_0.1UF0.1uFC0201
C25CAP NP_C0201_0.1UF0.1uFC0201
C26CAP NP_C0201_0.1UF0.1uFC0201
C27CAP NP_C0201_10PF10pFC0201
C28CAP NP_C0201_0.01UF0.01uFC0201
C29CAPNP_C0402_2.2UF/16V2.2uF/16VC0402
C30CAP NP_C0201_22PF22PFC0201
C31CAPNP_C0603_4.7UF/16V4.7uF/16VC0603
C32CAP NP_C0402_0.1UF0.1uFC0402
C33CAPNP_C0603_4.7UF/16V4.7uF/16VC0603
C34CAP NP_C0201_0.1UF0.1uFC0201
C35CAP NP_C0402_4.7UF4.7uFC0402
C36CAP NP_R0201_0.1UF0.1uFR0201
C37CAP NP_C0603_10UF10uFC0603
C38CAP NP_C0603_10UF10uFC0603
C39CAP NP_C0201_0.1UF0.1uFC0201
C40CAP NP_C0201_NCNCC0201
C41CAP NP_C0201_NCNCC0201
C44CAPNP_CAP0402_4.7UF/10V4.7uF/10VCAP0402
C45CAPNP_CAP0402_2.2UF/10V2.2uF/10VCAP0402
C46CAP NP_C0201_100PF100pFC0201
C47CAPNP_C0402_2.2UF/10V2.2uF/10VC0402
CN17P*0_0.8_6P0_83_6P*0.86P*0.86P0_83
D2DIODE BI-DIRTRIG_D0402_BTR04F1BTR04F15D0402
D3DIODE BI-DIRTRIG_D0402_BTR04F0BTR04F05D0402
D4DIODE_0_SOD323_1N58191N5819SOD323
D5DIODE_2_SOD523_SD103AXSD103AXSOD523
E1ANTENNA_AT18-A_AT18-AAT18-AAT18-A
E2ANTENNA_0_ANT2_NFC1NFC1ANT2
E3ANTENNA_0_ANT2_NFC2NFC2ANT2
FB1INDUCTOR_L0402_120R@100MHZ120R@100MHZL0402
J1QG-6428TSWKG01_QG-6428TSWKG01_QQG-6428TSWKG01QG-6428TSWKG01
L1INDUCTOR_L0402_15NH15nHL0402
L2INDUCTOR_L0603_10UH10uHL0603
L3INDUCTOR_L0201_3.9NH3.9nHL0201
L4INDUCTOR_L0201_NCNCL0201
L5INDUCTOR_L2016_LQH2MCN100M52LQH2MCN100M52L2016
L6INDUCTOR_L2016_LQM21PN1R0MC0LQM21PN1R0MC0L2016
LED1LED56/TO_6_LED0402_GTG1005SURCGTG1005SURCLED0402
M1MOTORAC_ZW0408TS4_4X4_4_FT4_4XFT4_4x4_4x8_6ZW0408TS4_4X4_4
P1T POINTS_P2XD0_83_VUSBVUSBP2XD0_83
P2T POINTS_P2XD0_83_GNDGNDP2XD0_83
P3T POINTS_TP_P_TOUCHKEYTouchKeyTP_P
Q1NPNBCE_0_SOT23_MMBT3904MMBT3904SOT23
R1RESISTOR_R0201_10K10KR0201
R2RESISTOR_R0201_18.2K_1%18.2K_1%R0201
R3RESISTOR_R0201_2K2KR0201
R4RESISTOR_R0201_10K10KR0201
R5RESISTOR_R0201_1M_1%1M_1%R0201
R6RESISTOR_R0201_1M_1%1M_1%R0201
R7RESISTOR_R0201_10K10KR0201
R8RESISTOR_R0201_680R680RR0201
R9RESISTOR_R0201_1M_1%1M_1%R0201
R10RESISTOR_R0201_196K_1%196K_1%R0201
R12RESISTOR_R0201_10K10KR0201
R13RESISTOR_R0201_10K10KR0201
R14RESISTOR_R0201_470R470RR0201
R15RESISTOR_R0603_25.5R25.5RR0603
R16RESISTOR_R0201_1M 1%1M 1%R0201
R17RESISTOR_R0201_160K1%160K 1%R0201
R18RESISTOR_R0201_2K2KR0201
R19RESISTOR_R0201_560K560KR0201
R20RESISTOR_R0201_100K100KR0201
R21RESISTOR_R0201_33R33RR0201
R22RESISTOR_R0402_1R1RR0402
R23RESISTOR_R0201_10R10RR0201
T1T POINT S_PAD_1_VBAT-VBAT-PAD_1
T2T POINT S_PAD_1_VBAT+VBAT+PAD_1
T3T POINTS_TEST_1_0MM_RXRXTEST_1_0MM
T4T POINTS_TEST_1_0MM_TXTXTEST_1_0MM
T5T POINTS_TEST_1_0MM_SWDIOSWDIOTEST_1_0MM
T6T POINTS_TEST_1_0MM_SWDCLKSWDCLKTEST_1_0MM
T7T POINTS_TEST_1_0MM_3V33V3TEST_1_0MM
T8T POINTS_TEST_1_0MM_GNDGNDTEST_1_0MM
T12T POINTS_TEST_1_0MM_9V9VTEST_1_0MM
U1XC6802A42XMR-G_SOT23-5_CE3153A4CE3153A420MSOT23-5
U2KX022-1020_LGA12_KX022-1020KX022-1020LGA12
U3NRF52832_0_QFN48_NRF52832-QFAA-nRF52832-QFAA-RQFN48
U4CE6232B33F_DFN1X1-4_CE6232B33FCE6232B33FDFN1X1-4
U5W25Q80BLEEK_0_USON8L_AT25SF081-AT25SF081-MAHD-TUSON8L
U6IQS211A_SOT23-6_IQS211AIQS211ASOT23-6
U7TPS61046_1_SOT23-5_SGM6601SGM6601SOT23-5
U8TPS61254_2_DSBGA9_TPS61256YFFRTPS61256YFFRDSBGA9
X1CRYSTAL1-4/SM_0_X2520_32MHZ32MHzX2520
X2CRYSTAL_X3215_32.768KHZ32.768KHzX3215
nRF52832.7z (164 KB, 下载次数: 19)
重要提示:PCB作品文件展下载说明
暑假期间,免费代管18-28岁小孩,限女性。
shuszhao | 2017-9-16 09:28:36 | 显示全部楼层
xnima_irumei | 2017-9-16 09:43:56 | 显示全部楼层
eyangbo | 2017-9-16 10:01:26 | 显示全部楼层
qqqqqiao | 2017-9-16 10:13:26 | 显示全部楼层
ylm113006016 | 2017-9-16 11:08:25 | 显示全部楼层
zzh | 2017-9-16 20:49:02 | 显示全部楼层
eyangbo | 2017-9-17 08:59:33 | 显示全部楼层
wcjcn | 2017-9-17 09:01:58 | 显示全部楼层
不错的蓝牙板子。。。。。
geekpower | 2017-9-17 21:03:26 | 显示全部楼层
长期免费代管18-28岁小
