[Allegro16.6以下] circuitco AM335X+TLK110+CY7C024AV+FT2232LQFN64 6层 PCB文件共享
查看8062 | 回复50 | 2019-7-9 16:02:18 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
D3LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D4598-8610-307F_LED4_1210SMD-1_59598-8610-307FLED4_1210SMD-1
D5598-8610-307F_LED4_1210SMD-1_59598-8610-307FLED4_1210SMD-1
D6LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D7LED_RED_SM_LED_0603_REDLEDRed LEDSM_LED_0603
D8LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D9LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D10LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D11LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D12DIODE_500MA20V_MBR0520L_MBR0520MBR0520LT1MBR0520L
D13DIODE_500MA20V_MBR0520L_MBR0520MBR0520LT1MBR0520L
D22DIODE_5ARECT_REV40V_2_SOD-123_MMBRX140-TPSOD-123
D23DIODE_SMCJ36CA_SMCJ36CA_SMCJ26CSMCJ26CASMCJ36CA
D24LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D25LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D26LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D27LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D28LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D29LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D30LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D31LED_GREEN_SM_LED_0603_GREENLEDGreen LEDSM_LED_0603
D32DIODE_500MA20V_MBR0520L_MBR0520MBR0520LT1MBR0520L
D33DIODE_5ARECT_REV40V_3_DO157LS_1B340A-13-FDO157LS_116X220SMA
FB1FER_180_200_0_SM-7351-IND-0805_150OHM800mASM-7351-IND-0805
FB2FER_180_200_0_SM-7351-IND-0805_150OHM800mASM-7351-IND-0805
FB3FER_180_200_0_SM-7351-IND-0805_150OHM800mASM-7351-IND-0805
FB4FERRITEEMI600OHM500MASMD0603_BL600OHM500mABLM18A
FB5FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB6FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB7FERRITEEMI600OHM500MASMD0603_BL600OHM500mABLM18A
FB8FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB9FERBEAD_180OHM200MA_SM-7351-IND150OHM800mASM-7351-IND-0805
FB10FER_180_200_0_SM-7351-IND-0805_150OHM800mASM-7351-IND-0805
FB11FER_180_200_0_SM-7351-IND-0805_150OHM800mASM-7351-IND-0805
FB12FER_180_200_0_SM-7351-IND-0805_150OHM800mASM-7351-IND-0805
J1CONN_PWRJACK_RAPC712_RAPC712_RARAPC712RAPC712
J2CONNECTORRJ45_10_100MB_6605728-RJ-45 10_100Mb6605728-1
J3CONNECTORRJ45_10_100MB_6605728-RJ-45 10_100Mb6605728-1
J4CONN PCB2_SIP2_50LS_CONN PCB 2CONN PCB 2SIP2_50LS
J5CONN PCB2_SIP2_50LS_CONN PCB 2CONN PCB 2SIP2_50LS
J6CONN PCB3_SIP3_50LS_CONN PCB 3CONN PCB 3SIP3_50LS
J7CONN PCB2_SIP2_50LS_CONN PCB 2CONN PCB 2SIP2_50LS
J8CONN_DSUB9F_NORCOMP_DB9F_SMD_COConn_DB9FNORCOMP_DB9F_SMD
J9CONN PCB20X2_HDR2X20_50LS_CONNCONN PCB 20x2HDR2X20_50LS
J10CONN PCB3_SIP3_50LS_CONN PCB 3CONN PCB 3SIP3_50LS
J12CONN PCB25X2_HDR2X25_50LS_CONNCONN PCB 25x2HDR2X25_50LS
J13CONN FLEX14_CON14_P5MM_3P75X9P10051922-1410ELFCON14_P5MM_3P75X9P5SMD
J14CONN_LEADSCREWDOWN_2PIN_CONN_OSOSTTC022162, DNICONN_OSTTC02
L14.7UH30%0.9ASMD_CHKFOOTPRINT_4.4.7uHCHKFOOTPRINT
L22.2UHINDUCTOR10%2.6ASMD_VLCF5022.2uHVLCF5020T
L32.2UHINDUCTOR10%2.6ASMD_VLCF5022.2uHVLCF5020T
L42.2UHINDUCTOR10%2.6ASMD_VLCF5022.2uHVLCF5020T
L5DA2304-ALB_DA2304_DA2304DA2304DA2304
L6INDUCTOR_IND108SMD_110X102_VLF3VLF3010AT-2R2M1R0IND108SMD_110X102
L7INDUCTORIRON_IND_354SMD_400SQ_68uHIND_354SMD_400SQ
P2HDR_10X2_CJTAG_0_HEADER10X2_SMDCTI JTAG,DNIHEADER10X2_SMD
P3MICROSD_CONN_8_SD-MICRO-SCHA5B0SCHA5B0200SD-MICRO-SCHA5B0300
P4MINI-USB-AB-SOCKET_USB-MINI-SMTmini USB-BUSB-MINI-SMT-NUM
Q1RN1907_SMINI6-F3-B_DMC56404DMC56404SMINI6-F3-B
Q2RN1907_SMINI6-F3-B_DMC56404DMC56404SMINI6-F3-B
Q3RN1907_SMINI6-F3-B_DMC56404DMC56404SMINI6-F3-B
Q4RN1907_SMINI6-F3-B_DMC56404DMC56404SMINI6-F3-B
Q5RN1907_SMINI6-F3-B_DMC56404DMC56404SMINI6-F3-B
S1SW_DP_MOM_SW3_4X2P5_DISCRETE_B3B3U-1100SW3_4X2P5
TP1TESTPOINT_SMD1MMCIRCLE_TP_SMD1MTP1mmTP_SMD1MMCIRCLE
TP3TESTPOINTTHROUGHHOLE_TH_TP_5002TPTH_TP_5002
TP4TESTPOINT_SMD1MMCIRCLE_TP_SMD1MTP1mmTP_SMD1MMCIRCLE
TP5TESTPOINT_SMD1MMCIRCLE_TP_SMD1MTP1mmTP_SMD1MMCIRCLE
TP7TESTPT1_TP60C_SMD_TESTPT1TESTPT1TP60C_SMD
TP8TESTPT1_TP60C_SMD_TESTPT1TESTPT1TP60C_SMD
TP9TESTPT1_TP60C_SMD_TESTPT1TESTPT1TP60C_SMD
U1TPS65910_0_U_48_RSL_TPS65910TPS65910U_48_RSL
U2TPS71718_SMDSC70-5_TPS71718TPS71718SMDSC70-5
U3IC_SN74AUP2G08_8-VSSOP_U_8_DCU_SN74AUP2G08U_8_DCU
U4IC_SN74AUP2G08_8-VSSOP_U_8_DCU_SN74AUP2G08U_8_DCU
U5IC_AM335X_ZCE_2_AM33XX_15X15_AMAM335X_ZCZAM33XX_15X15
U6LM94022_SC70-5_LM94022LM94022SC70-5
U7MEM_MT47H64M16_FBGA84_1_BGA84_8MT47H128M16RT-25E:CBGA84_8X12P5_P8MM
U8IC_FT2232H_LQFP64_LQFP64_10X10_FT2232LQFN64LQFP64_10X10
U9CY7C024AV/025AV/026AV_0_TQFP-10CY7C024AV/025AV/026AVTQFP-100
U10M29W128G_0_TFBGA48_M29W160EB70ZM29W160EB70ZA6ETFBGA48
U11SN74ALVCH16374DGV_0_TVSOP-48_SNSN74ALVCH16374DGVTVSOP-48
U12TLK110_2_HTQFP_48PIN_TLK110TLK110HTQFP_48PIN
U13SN74LVC1G08DCKT_SC70_SM-SO-SC70SN74LVC1G08SM-SO-SC70-5
U14TLK110_2_HTQFP_48PIN_TLK110TLK110HTQFP_48PIN
U15SN74LVC1G08DCKT_SC70_SM-SO-SC70SN74LVC1G08SM-SO-SC70-5
U16ISO1176T_U_16_DW_ISO1176TISO1176TU_16_DW
U17IC_93C46B_SSOT23-6_SOT23-6_93C493C46B_SOT23-6SOT23-6
U18TPS76650_SOIC_8_TPS76650TPS76650SOIC_8
U19W25Q64_SOIC8_265_W25Q64W25Q64SOIC8_265
U20ISO1050_SO8_W_DUB_ISO1050ISO1050SO8_W_DUB
U21CAT24C256W_SOIC_8_CAT24C256WCAT24C256WSOIC_8
U22SN74LVC1G06DCK_0_DCK5_SN74LVC1GSN74LVC1G06DCKDCK5
U23SN74LVC1G07DCK_DCK5_SN74LVC1G07SN74LVC1G07DCKDCK5
U25SN65HVS882_U_28_PWP_SN65HVS882SN65HVS882U_28_PWP
U26TPIC2810_U_16_D_TPIC2810TPIC2810U_16_D
U27TPS61041DBV_DBV5_TPS61041DBVTPS61041DBVDBV5
U28TPS5410D_SOIC-8_TPS5410DTPS5410DSOIC-8
U29SN74CBQ3306APW_PW8_SN74CBQ3306ASN74CBQ3306APWPW8
Y1CRYS_32_768KHZ_SMD32_MC-306_32.32.768KHz MC-306MC-306
Y2CRYS_24MHZ_SCC_XTAL4_3P2X2P5_SM24MHzXTAL4_3P2X2P5_SMD
Y4CRYSTAL25MHZABM3_SM_OSC_ABM3_2525MHzSM_OSC_ABM3
Y6XTAL_HC-49SMT12.000MHzXTAL4_3P2X5SMD
重要提示:PCB作品文件展下载说明
老吴 | 2019-7-9 16:03:23 | 显示全部楼层
PCB文件共享。没原理图
AM335X.7z (1.28 MB, 下载次数: 31)
bidezhi7777 | 2019-7-9 22:09:31 | 显示全部楼层
kanxue_nmg | 2019-7-10 07:04:22 | 显示全部楼层
单枪舞九州 | 2019-7-10 07:18:00 | 显示全部楼层
发电机 | 2019-7-10 08:35:08 | 显示全部楼层
linyuanfei | 2019-7-10 08:49:56 | 显示全部楼层
dancell | 2019-7-10 08:50:13 | 显示全部楼层
as3218710 | 2019-7-10 08:50:37 | 显示全部楼层
xiaoxiao116 | 2019-7-10 08:50:51 | 显示全部楼层
