[Allegro16.6以下] LAN8710A+MP1530DM+TPD4E001DBV 做的AM335X底板PCB和原理图(不含核
查看4628 | 回复20 | 2019-7-18 11:44:53 | 显示全部楼层 |阅读模式
重要提示:PCB作品文件展下载说明
BK1L-BT_BAT_CR1220_A_CR1220CR1220BAT_CR1220_A
BZK1L-BUZER-A_BUZZER_9P50_A_BZ/AX-1BZ/AX-1003-LFBUZZER_9P50_A
D1L-DIODE-SCHOTTKY_DO_SOD_323_NSRNSR1020MW2T1GDO_SOD_323
D2L-DIODE-SCHOTTKY_DO_SOD_323_NSRNSR1020MW2T1GDO_SOD_323
D3L-DIODE-SCHOTTKY_DO_SOD_323_NSRNSR1020MW2T1GDO_SOD_323
D8DIODE_DUAL_0_SOT-23_BAT54SBAT54SSOT-23
D9DIODE_DUAL_0_SOT-23_BAT54SBAT54SSOT-23
D10L-DIODE-SCHOTTKY_DO_SMC_B560CB560CDO_SMC
D11DIODE_0_SOD123_IN5819IN5819SOD123
D12DIODE_DUAL_0_SOT-23_BAT54SBAT54SSOT-23
D13L-DIODE-SCHOTTKY_DO_SOD_123_MBRMBR230LSFT1GDO_SOD_123
D14L-DIODE-ZENER_DO_SOD_323_MM3Z5VMM3Z5V6T1GDO_SOD_323
D15L-DIODE-SCHOTTKY_DO_SMC_B560CB560CDO_SMC
D16L-DIODE-TVS_DO_SMC_1SMC24AT3G1SMC24AT3GDO_SMC
D17L-DIODE-SCHOTTKY_2_SOD-123_MBR2MBR230LSFT1G/SOD-123SOD-123
D18LED_0_LED-100_3_IC_REDREDLED-100_3
D19LED_0_LED-100_3_IC_REDREDLED-100_3
D20LED_0_LED-100_3_IC_REDREDLED-100_3
D21L-DIODE-ZENER_DO_SOD_323_MM3Z5VMM3Z5V6T1GDO_SOD_323
FA1L-FUSE_FS1812_FSMD300R/F1812FSMD300R/F1812FS1812
FA2L-FUSE_FS1812_DNU/F1812DNU/F1812FS1812
FL1L-PPTC_FS1206_FSMD150-1206R/FS1FSMD150-1206R/FS1206FS1206
J1CON5_A2001WVB_NP_5P_CON5CON5A2001WVB_NP_5P
J2CON8_SIP-8P-2_54_CON8CON8SIP-8P-2_54
J3CON8_SIP-8P-2_54_CON8CON8SIP-8P-2_54
J4USB_MICROAB_8_USB_S_47589-000147589-0001USB_S
J5MICROSD_CONN_2_SDCON-C_ALPSSCHALPS SCHA4B0100SDCON-C
J712 HEADER_SIP12-80_12HEADER12 HEADERSIP12-80
J8L-70LCD-50PIN_2_L-FPC0_5-50B-S170LCD-50PIN-FPCL-FPC0_5-50B-S1
J9CON6_USB_A_180D_CON6CON6USB_A_180D
J10CON3_SIP-3P-2_54_DEBUGDEBUGSIP-3P-2_54
J11CON6_DCN1X6-2_0B_CON6CON6DCN1X6-2_0B
JA3L-FPC-4P-S1_L-FPC1_0-4A-S1_FPC-FPC-4P-S1/TTW410514/90mm-LeftOutL-FPC1_0-4A-S1
JL1L-CON-1X4_1_A2001WVB_NP_4P_A200A2001WVB_NP_4PA2001WVB_NP_4P
JT1L-CON-1X4_1_A2001WVB_NP_4P_A200A2001WVB_NP_4PA2001WVB_NP_4P
JT2L-CON-1X4_1_A2001WVB_NP_4P_A200A2001WVB_NP_4PA2001WVB_NP_4P
L1INDUCTOR_0_L4X4_10UH/L4X410uH/L4X4L4X4
L2L-INDUCTOR_L-L-SCDS5D_2.2UH/SCD2.2uH/SCDS5D28-2R2L-L-SCDS5D
LA1L-INDUCTOR_L_SCDS5D_2.2UH/SCDS52.2uH/SCDS5DL_SCDS5D
LA2L-INDUCTOR_L_SLF12_5.6UH/SLF1275.6uH/SLF1275T-5R6T-NL_SLF12
LC1L-FILTERS-CM-A_L_ACM2012_ACM201ACM2012-121-2P-T002L_ACM2012
LL1L-FILTERS-CM-A_L_ACM2012_ACM201ACM2012-121-2P-T002L_ACM2012
M1T-MARK_MARK_1P00_A_MARKMarkMARK_1P00_A
M2T-MARK_MARK_1P00_A_MARKMarkMARK_1P00_A
M3T-MARK_MARK_1P00_A_MARKMarkMARK_1P00_A
M4T-MARK_MARK_1P00_A_MARKMarkMARK_1P00_A
MA1L-MT-A_HOLE284CIR126_MTMTHOLE284CIR126
MA2L-MT-A_HOLE284CIR126_MTMTHOLE284CIR126
MA3L-MT-A_HOLE284CIR126_MTMTHOLE284CIR126
MA4L-MT-A_HOLE284CIR126_MTMTHOLE284CIR126
Q1NPN_SOT_23_A_SS8050SS8050SOT_23_A
Q2L-DIODE-SOT23-DP_SOT_23_A_NUP21NUP2105LSOT_23_A
Q3L-DIODE-SOT23-DP_SOT_23_A_SM36TSM36T1GSOT_23_A
Q4L-DIODE-SOT23-DP_SOT_23_A_SM36TSM36T1GSOT_23_A
Q5L-DIODE-SOT23-DP_SOT_23_A_NUP21NUP2105LSOT_23_A
QK1L-MOSFET-P_SOT_23_A_IRLML5203IRLML5203SOT_23_A
QK2L-MOSFET-P_SOT_23_A_IRLML5203IRLML5203SOT_23_A
RPG1L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%RP4_0402
RPG2L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%RP4_0402
RPG3L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%RP4_0402
RPG4L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%RP4_0402
RPG5L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%RP4_0402
RPG6L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%RP4_0402
RPG7L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%RP4_0402
RPG8L-RP4_RP4_0402_0R/RP4-0402/1%0R/RP4-0402/1%RP4_0402
SG1L-DIP-2-SOC_SW_SOP_4P_SW-2-SOCSW-2-SOCSW_SOP_4P
SW1SWPUSHBUTTON_SW_6X3_USER1USER1SW_6X3
SW2SWPUSHBUTTON_SW_6X3_USER2USER2SW_6X3
SW3SWPUSHBUTTON_SW_6X3_PWR_ONPWR_ONSW_6X3
SW4SWPUSHBUTTON_SW_6X3_RSTRSTSW_6X3
U1L-LS335X_QDIP_176P_2P00_B_MT_LSLS335XQDIP_176P_2P00_B_MT
U2L-TPD4E001DBV_SOT23_6P_ESD_TPD4TPD4E001DBVSOT23_6P_ESD
U4SN65HVD234_SOP-8D_SN65HVD234DRSN65HVD234DRSOP-8D
U5MP1530_5_TSSOP16_MP1530DMMP1530DMTSSOP16
U6L-MAX202E_SOIC_16P_N_A_MAX3232EMAX3232ESESOIC_16P_N_A
U7L-TPS54360_HSOIC_8P_EP_TPS54560TPS54560DDHSOIC_8P_EP
U8L-TPS736XX_L-SOT23-5_TPS73601DBTPS73601DBV/SOT23-5L-SOT23-5
U9L-LM2832-6WSON_WSON_6P_P_LM2832LM2832XSDWSON_6P_P
U10L-MAX485E_SOIC_8P_N_MAX13487MAX13487SOIC_8P_N
U11L-FX-T_F_XT_8P_A_F0505XT-1WR2/NF0505XT-1WR2/NCF_XT_8P_A
U12L-TPS61165_L-SOT23-6_TPS61165DBTPS61165DBVL-SOT23-6
U13L-TPD4E001DBV_SOT23_6P_ESD_TPD4TPD4E001DBVSOT23_6P_ESD
U14L-SN74AHC1G00_SC70_5P_A_SN74AHCSN74AHC1G00DCKSC70_5P_A
U15L-DS1339_UMAX_8P_A_DS1339U-33DS1339U-33UMAX_8P_A
U16L-SN74LVC1G07_SC70_5P_A_SN74LVCSN74LVC1G07DCKSC70_5P_A
U17L-SN74LVC1G07_SC70_5P_A_SN74LVCSN74LVC1G07DCKSC70_5P_A
U18L-SN74LVC1G08_L-SC70-5_SN74LVC1SN74LVC1G08DCK/SC70-5L-SC70-5
U19L-SN74AHC1G32_L-SC70-5_SN74AHC1SN74AHC1G32DCK/SC70-5L-SC70-5
U21L-TPD4E001DBV_SOT23_6P_ESD_TPD4TPD4E001DBVSOT23_6P_ESD
U22L-TPD4E001DBV_SOT23_6P_ESD_TPD4TPD4E001DBVSOT23_6P_ESD
U23L-ADUM1201_SOIC_8P_N_SW_ADUM120ADuM1201B/NCSOIC_8P_N_SW
U24L-ADUM1201_SOIC_8P_N_SW_ADUM120ADuM1201B/NCSOIC_8P_N_SW
U25L-ADUM1201_SOIC_8P_N_SW_ADUM120ADuM1201B/NCSOIC_8P_N_SW
U27L-ADUM1201_SOIC_8P_N_SW_ADUM120ADuM1201B/NCSOIC_8P_N_SW
U28LAN8710QFN32_1_QFN32_5X5MM_EP3LAN8710AQFN32_5X5MM_EP3P3MM
U29SG16116_SG16116_SG16116SG16116SG16116
Y1L-CRYSTAL-4_CY_3225_4P_25MHZ/X325MHz/X3225/NPCY_3225_4P
YK1L-CRYSTAL_CY_3215_A_32768HZ/X3232768Hz/X3215/NPCY_3215_A
重要提示:PCB作品文件展下载说明
armclub | 2019-7-18 11:45:45 | 显示全部楼层
AM335X.7z (1.05 MB, 下载次数: 26)
cy0913 | 2019-7-18 13:21:25 | 显示全部楼层
i_333333 | 2019-7-18 13:32:05 | 显示全部楼层
非常感谢楼主大神的分享
学海无涯 | 2019-7-19 08:10:53 | 显示全部楼层
谢谢分享,长见识了。
zqshbs | 2019-7-19 08:50:55 | 显示全部楼层
yhgwork | 2019-7-19 13:08:30 | 显示全部楼层
i_333333 | 2019-7-19 13:36:30 | 显示全部楼层
非常感谢楼主大神的分享
南亭好远 | 2019-8-10 13:39:15 | 显示全部楼层
mikewen | 2019-9-9 06:46:55 | 显示全部楼层
终身成就奖社区居民忠实会员宣传大使奖优秀斑竹奖
